取消
显示结果
搜索替代
您的意思是:
查看次数
16
有帮助
8
回复
由于现在的WLC支持的AP数量比较少,重新买了license,license如何导入?
YW914132370
WLC上如何导入license?麻烦提供下相关文档,谢谢!
1 个已接受解答
已接受的解答
ilay
一般来说,当你拿到license之后,你可以直接将文件通过web管理界面上传只wlc,保存之后重启即可。
路径--web管理界面--Management--Software Activation --Command --install License ,然后通过tftp上传,保存即可。
cisco的wlc的configure guide上面是有方法的。
参考文档:http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_011.html
Installing a LicenseInstalling a License (GUI)
Step 1
ChooseManagement >Software Activation >Commands to open the License Commands page.
Step 2
From the Action drop-down list, chooseInstall License. The Install License from a File section appears.
Step 3
In the File Name to Install text box, enter the path to the license (*.lic) on the TFTP server.
Step 4
ClickInstall License. A message appears to show whether the license was installed successfully. If the installation fails, the message provides the reason for the failure, such as the license is an existing license, the path was not found, the license does not belong to this device, you do not have correct permissions for the license, and so on.
Step 5
If the end-user license agreement (EULA) acceptance dialog box appears, read the agreement and clickAccept to accept the terms of the agreement.
Note
Typically, you are prompted to accept the EULA for evaluation, extension, and rehost licenses. The EULA is also required for permanent licenses, but it is accepted during license generation.
Step 6
Save a backup copy of all installed licenses as follows:
  • From the Action drop-down list, chooseSave License.
  • In the File Name to Save text box, enter the path on the TFTP server where you want the licenses to be saved.
    Note
    You cannot save evaluation licenses.
  • ClickSave Licenses.
Step 7
Reboot the controller.
Note
We recommend that you reset the system to ensure that the newly installed license file is saved in the WLC.
在原帖中查看解决方案
8 条回复8
ilay
Step 1
Step 2
Step 3
Step 4
Step 5
Note
Step 6
    Note
Step 7
Note
fortune
Step 1 Choose Management > Software Activation > Commands to open the License Commands page.
Step 2 From the Action drop-down list, choose Install License. The Install License from a File section appears.
Step 3 In the File Name to Install text box, enter the path to the license (*.lic) on the TFTP server.
Step 4 Click Install License. A message appears to show whether the license was installed successfully. If the installation fails,
Step 5 If the end-user license agreement (EULA) acceptance dialog box appears, read the agreement and click Accept to accept
Note
Step 6 Save a backup copy of all installed licenses as follows:
a) From the Action drop-down list, choose Save License.
b) In the File Name to Save text box, enter the path on the TFTP server where you want the licenses to be saved.
licenses.
Note
c) Click Save Licenses.
Step 7 Reboot the controller.
WLC.
pinfeng
YW914132370
vsop5207 发表于 2016-8-16 20:10 back.gif
Step 2 ...
非常感谢,谢谢。我了解了。。。
YW914132370
gengchunlin 发表于 2016-8-16 22:51 back.gif
路径--w ...
非常感谢,我知道了。。。
YW914132370
快捷链接
