还是相同的位置,切换到Network菜单,然后将802.11a network status 的enabled勾选去掉,apply之后就可以调整了,调整完之后再在该处重新开启即可。
Table 1. Cisco 2500 Series Wireless Controller Features and Benefits
Feature |
Benefits |
Scalability |
● Supports up to 75 access points
● Supports up to 1000 clients
Ease of Deployment |
● For quick and easy deployment Access Points can be connected directly to 2504 Wireless LAN Controller via two PoE (Power over Ethernet) ports
High Performance |
● Wired-network speed and nonblocking performance for 802.11n and 802.11ac networks. Supports up to 1 Gbps throughput
RF Management |
● Provides both real-time and historical information about RF interference impacting network performance across controllers, via systemwideCisco CleanAir® technology integration
Table 2. Product Specifications for the Cisco 2500 Wireless Controller
