取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
8
回复
AIR-CT2504-K9 的速度上限
CybertronpeopleV
问下大佬这个AC  可以支持802.11AC吗
1 个已接受解答
已接受的解答
还是相同的位置,切换到Network菜单,然后将802.11a network status 的enabled勾选去掉,apply之后就可以调整了,调整完之后再在该处重新开启即可。
在原帖中查看解决方案
8 条回复8
ilay
是否支持802.11ac取决于WLC的软件版本,8.0.x之后的软件版本都支持802.11ac的协议,但是否能跑满ac的上限速率取决于ap的性能、连接人数、无线环境的质量,信号强度、及频宽设置等等。理想状况下是没啥问题的
再者2504总共只有4个1G接口,最大也就4G的带宽,太大的吞吐其实也撑不住
大佬,选的时候没有.11ac  。。还需要配置哪里吗
1.ap得支持ac
2.控制器上面WIRELESS--802.11a/n/ac里面得把ac启用起来可以
3.你截图的那个位置是无线ssid的射频选项,选择该ssid工作在哪个频段,不涉及ac的设置
谢谢大佬,发现是Channel Width 值设得太低   修改提示 failed to set channel width network must disabled to update channel width 这里的关闭网络是指关闭SSID吗
大佬 ,再咨询一下,把AC 4个接口都接在3层上,需要做啥配置吗
sufee
明白了!!!再好好学习!
Table 1.       Cisco 2500 Series Wireless Controller Features and Benefits
Feature
Benefits
Scalability
●  Supports up to 75 access points
●  Supports up to 1000 clients
Ease of Deployment
●  For quick and easy deployment Access Points can be connected directly to 2504 Wireless LAN Controller via two PoE (Power over Ethernet) ports
High Performance
●  Wired-network speed and nonblocking performance for 802.11n and 802.11ac networks. Supports up to 1 Gbps throughput
RF Management
●  Provides both real-time and historical information about RF interference impacting network performance across controllers, via systemwideCisco CleanAir® technology integration
Table 2.       Product Specifications for the Cisco 2500 Wireless Controller
Item
Specification
Wireless Standards
IEEE 802.11a, 802.11ac, 802.11b, 802.11g, 802.11d, WMM/802.11e, 802.11h, 802.11k, 802.11n, 802.11r, 802.11u, 802.11w, 802.11ac
Wired/Switching/Routing
IEEE 802.3 10BASE-T, IEEE 802.3u 100BASE-TX specification, 1000BASE-T, and IEEE 802.1Q VLAN tagging
https://www.cisco.com/c/en/us/products/collateral/wireless/2500-series-wireless-controllers/data_sheet_c78-645111.html
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
快捷链接
