取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Cisco 2500 Series Wireless Controller恢复出厂设置后,无法进入系统
15937771367
控制器被恢复出厂设置后,无法进入系统,以下为WLC启动信息:
WLCNG Boot Loader Version 1.0.20 (Built on Jan 9 2014 at 19:02:44 by cisco)
Board Revision 0.0 (SN: PSZ20211GA5, Type: AIR-CT2504-K9) (P)
Verifying boot loader integrity... OK.
OCTEON CN5230C-SCP pass 2.0, Core clock: 750 MHz, DDR clock: 330 MHz (660 Mhz data rate)
CPU Cores: 4
DRAM: 1024 MB
Flash: 32 MB
Clearing DRAM........ done
Network: octeth0', octeth1, octeth2, octeth3
' - Active interface
E - Environment MAC address override
CF Bus 0 (IDE): OK
IDE device 0:
- Model: 1GB CompactFlash Card Firm: CF B61FK Ser#: A181112714A1Yb2H1ISH
- Type: Hard Disk
- Capacity: 977.4 MB = 0.9 GB (2001888 x 512)
Press <ESC> now to access the Boot Menu...
Loading backup image (Image not found)
** Unable to read "linux.bak.img" from ide 0:2 **
** Launch failure **
Loading primary image (Image not found)
** Unable to read "linux.pri.img" from ide 0:2 **
Boot Loader Menu
1. Run primary image (Image not found)
2. Run backup image (Image not found) - Active
3. Change active boot image
4. Clear configuration
5. Format FLASH Drive
6. Manually update images
Enter selection:
这是需要重新刷系统吗?那位大神知道一下感谢
3 条回复3
balaji.bandi
Contact TAC for help.
BB
ilay
设备的primary和backup image都已经是失效状态了,需要重新刷系统才能使用
刷系统需要用的RTOS的文件,这个只能从tac那里获取,外边几乎找不到文件
参考教程:
https://community.cisco.com/t5/%E6%97%A0%E7%BA%BF%E6%96%87%E6%A1%A3/%E5%8E%9F%E5%88%9B-cisco-wlc%E7%A0%96%E6%9C%BA%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D/ta-p/4374370
参考下如下连接中的“解决方法”,里面有RTOS和FP,仅供参考!
https://www.cnblogs.com/MomentsLee/p/10579380.html
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
快捷链接
