取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
7
回复
cisco4506交换机CPU告达到峰值94%,如何处理
supershunge
7 条回复7
one-time
Level 13
Level 13
感谢您的提问!稍后会有小伙伴为您解答的!
ni-weijian
是不是中毒了,?????????可以去查下 官网上查看下Cat4k Mgmt LoPri这个进程是由什么引起
fortune
62.65% 0 Cat4k Mgmt LoPri 这个进程,你可以根据这个去谷歌查找,一般都有解决方案。
show proc cpu | ex 0.00
http://blog.sina.com.cn/s/blog_62f9aae70101069x.html
https://www.baidu.com/baidu?tn=monline_3_dg&ie=utf-8&wd=Cat4k+Mgmt+LoPri+
sdf1
1.debug platform packet all buffer
2.show platform cpu packet buffered
看看都是哪些流量到了CPU。
cruiseluo
CPU utilization for five seconds: 87%/3%; one minute: 89%; five minutes: 90%
15 1745897082100583975 83 19.11% 19.19% 20.28% 0 ARP Input
54 5675266722171792003 261 59.75% 62.09% 62.65% 0 Cat4k Mgmt LoPri
第一行87%/3%表示cpu总体利用率达到了87%,但interrupt percentage只有3%,表明交换机接收的流量不大,在正常范围内。
后面两行表明有可能出现MAC地址在不同端口摆动,查一下是否有应该配置Etherchannel的地方没有配置或者配置得不对。
再检查一下生成树协议,看看各个vlan的生成树root是不是不在你预想的设备上(show spanning-tree root)
使用命令show spanning-tree detail | in ieee|from|occur|is exec查一下是否有某个vlan的topology changes太高
最后回想一下最近网络是否有变动,网络接的设备是否有变动
supershunge
15 17458970821005839 ...
sh spanning-tree detail | include ieee | from |occur |is exec
VLAN0001 is executing the ieee compatible Spanning Tree protocol
from GigabitEthernet3/12
VLAN0201 is executing the ieee compatible Spanning Tree protocol
from GigabitEthernet3/19
VLAN0202 is executing the ieee compatible Spanning Tree protocol
VLAN0203 is executing the ieee compatible Spanning Tree protocol
VLAN0204 is executing the ieee compatible Spanning Tree protocol
VLAN0205 is executing the ieee compatible Spanning Tree protocol
VLAN0206 is executing the ieee compatible Spanning Tree protocol
VLAN0207 is executing the ieee compatible Spanning Tree protocol
VLAN0208 is executing the ieee compatible Spanning Tree protocol
VLAN0209 is executing the ieee compatible Spanning Tree protocol
VLAN0210 is executing the ieee compatible Spanning Tree protocol
VLAN0211 is executing the ieee compatible Spanning Tree protocol
VLAN0213 is executing the ieee compatible Spanning Tree protocol
VLAN0214 is executing the ieee compatible Spanning Tree protocol
VLAN0215 is executing the ieee compatible Spanning Tree protocol
VLAN0401 is executing the ieee compatible Spanning Tree protocol
VLAN0402 is executing the ieee compatible Spanning Tree protocol
from Port-channel1
VLAN0403 is executing the ieee compatible Spanning Tree protocol
VLAN0404 is executing the ieee compatible Spanning Tree protocol
VLAN0405 is executing the ieee compatible Spanning Tree protocol
VLAN0406 is executing the ieee compatible Spanning Tree protocol
VLAN0407 is executing the ieee compatible Spanning Tree protocol
VLAN0408 is executing the ieee compatible Spanning Tree protocol
VLAN0409 is executing the ieee compatible Spanning Tree protocol
VLAN0410 is executing the ieee compatible Spanning Tree protocol
VLAN0411 is executing the ieee compatible Spanning Tree protocol
VLAN0412 is executing the ieee compatible Spanning Tree protocol
VLAN0413 is executing the ieee compatible Spanning Tree protocol
VLAN0414 is executing the ieee compatible Spanning Tree protocol
VLAN0415 is executing the ieee compatible Spanning Tree protocol
VLAN0603 is executing the ieee compatible Spanning Tree protocol
VLAN0800 is executing the ieee compatible Spanning Tree protocol
VLAN0803 is executing the ieee compatible Spanning Tree protocol
VLAN0999 is executing the ieee compatible Spanning Tree protocol
VLAN1603 is executing the ieee compatible Spanning Tree protocol
from GigabitEthernet3/19没有发现什么异常 ,很奇怪
supershunge
VLAN0001 is executing the ieee co ...
sh platform cpu packet statistics
RkiosSysPacketMan:
Packet allocation failures: 0
Packet Buffer(Software Common) allocation failures: 0
Packet Buffer(Software ESMP) allocation failures: 0
Packet Buffer(Software EOBC) allocation failures: 0
Packet Buffer(Software SupToSup) allocation failures: 0
IOS Packet Buffer Wrapper allocation failures: 0
Packets Dropped In Processing Overall
Total 5 sec avg 1 min avg 5 min avg 1 hour avg
1240364 0 0 0 0
Packets Dropped In Processing by CPU event
Event Total 5 sec avg 1 min avg 5 min avg 1 hour avg
Sa Miss 366685 0 0 0 0
Input Acl Fwd 1 0 0 0 0
Input ACl Copy 873678 0 0 0 0
Packets Dropped In Processing by Priority
Priority Total 5 sec avg 1 min avg 5 min avg 1 hour avg
Normal 759914 0 0 0 0
Medium 398343 0 0 0 0
High 76894 0 0 0 0
Crucial 5213 0 0 0 0
Packets Dropped In Processing by Reason
Reason Total 5 sec avg 1 min avg 5 min avg 1 hour avg
STPDrop 41 0 0 0 0
Tx Mode Drop 1240323 0 0 0 0
Total packet queues 64
Packets Received by Packet Queue
Queue Total 5 sec avg 1 min avg 5 min avg 1 hour avg
Input ACL fwd(snooping) 586332 0 0 0 0
Host Learning 366684 0 0 0 0
L2 Control 208824844 34 21 17 9
Input ACL log, unreach 873646 0 0 0 0
Ttl Expired 12246 0 0 0 0
Adj SameIf Fail 3804 0 0 0 0
L2 router to CPU, 7 27564730392 32097 30675 21635 13358
L3 Glean, 7 12059465 9 4 0 0
L3 Receive, 7 45005975 8 6 3 0
Packets Dropped by Packet Queue
L2 router to CPU, 7 597776026 1057 1175 670 123
L3 Glean, 7 48134 0 0 0 0
快捷链接
