Dear All,
I'm having a problem with ap's not sending 802.11ac channels right now. We confirmed that ap's used to send normally.
WLC Model:5508. WLC Version:8.2.151.0
AP Model:AIR-CAP3602E-C-K9
I comfirmed the follow information
Country is correct
time and zone is correct
802.11a Network Status is enable but the AP detail information show the 11ac Supported as No
I can see the AP under 802.11a/n/ac Radios
Could you please help me solve this problem, more information as picture.
many thanks
The answer is that there is no AIR-RM3000AC module and the AP uses the PPOE power from the switch.
For example, AP3-6 as an attachment, from switch_3.
Without the AC radio module, the AP can only bond up to 40 Mhz channel width.
Hi, Leo
Could you please tell me that which part should I change? Is there a risk in changing the bond to 40Mhz channel width.
e.g. software and hardware failure?
The Cisco Aironet® 3600 Series sustains reliable connections at higher speeds further from the access point than competing solutions, resulting in up to three times more availability of 450 Mbps rates, and optimizing the performance of more mobile devices. Cisco® Aironet 3600 Series is an innovative, modular platform that offers unparalleled investment protection with future module expansion to support incoming 802.11ac clients with 1.3 Gbps rates, or offer comprehensive security and spectrum monitoring and control.
If you want to support 11ac , we need to bug CISCO AIR-RM3000AC-x-K9= 802.11ac Wave 1 Module for AP3600.
Modifying the bandwidth can increase a certain bandwidth, but it may increase the risk of interference.
You can configure the band bandwidth in the "red box"
Unfortunately, after this operation change, the device still cannot discover the 802.11a
What network environment is the AP in?
Can the worst wireless client support 40 Mhz or not? If the worst wireless client cannot/do-not support 40 Mhz then stay with 20 Mhz.
There is nothing wrong with 20 Mhz because MIMO can do all the work.
hi,
The AP working at Office area, so there is no interference.
The problem I am currently experiencing is that the device is not searching for 802.11a/ac
many thanks
Wireless clients cannot see the 5.0 Ghz radio? Is this the root of the problem?
If this, indeed, is the problem, does the wireless client even have a 5.0 Ghz radio? Remember, the cheapest shonkiest wireless NIC will always have 2.4 Ghz radio.
Yes, correct.
Wireless devices can now only search for 802.11b/g, not 802.11a/ac. Include the laptop.
Hi, Leo
I confirmed that the device support the 802.11a/ac, I can see the device online at different model AP
On the WLC, go to Monitor > All APs.
Pick an AP that is not broadcasting in 5.0 Ghz.
Go to the Interfaces tab.
Post the screenshot of the Interfaces. tab.
If that laptop is Windows-based, post the top screenshot of the command "netsh wlan show drivers".
Hi, Leo
I can see the detail of ap show up the 11ac support as no, and the laptop show connect with 802.11n
and I confirmed that before I can search for 802.11a/ac through this ap
