取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
C9600 series switch
hdzk
Is the C9600 series switch a Layer 4 switch, or what functions are required to define a switch as a Layer 4 switch?
Can the following prove that it is a Layer 4 switch or has Layer 4 switching capabilities?
2 条回复2
The Cisco Catalyst 9600 series is primarily a Layer 3 modular core switch, but it does have some Layer 4 capabilities. It supports Layer 2, Layer 3, and some Layer 4 functionalities, including:
  • Layer 2 switching: VLANs, STP, EtherChannel
  • Layer 3 routing: OSPF, EIGRP, BGP, VRF
  • Layer 4 features: Access Control Lists (ACLs) based on TCP/UDP ports .etc
The above content only shows that it may support some L4 functions.
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
hdzk
Thank you
快捷链接
