取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Hi all, I'm having some serious technical issues with establishin
Hi all,
I'm having some serious technical issues with establishing a site-to-site VPN to Symantec's Web Security Service (WSS). Getting technical support to help is also really really painful. After three months of pulling my hair out I finally had a WebEX troubleshooting session, but unfortunately it was unsuccessful and we didn't get anywhere.
This is my setup
                                            Customer FW              NAT - Edge FW                                                              ep.threatpulse.net
{Multiple DMZ s / LANS}-----(>|) ASA FW ---------- (FGT-FW)-----------(Internet)---------(Symantec WSS)---(Proxy)
The customer firewall is the  ASAv Firewall
The Fortigate is a perimeter firewall for all customers and NATs the outside interface of the ASA firewall  to a Public IP address and in terms of security policy its wide open (any any). The ASA is more restrictive.
I followed the following KB from Symantec (or Broadcom as they are currently known as) but with some tweaks. I will explain:
KB: https://knowledge.broadcom.com/external/article/174263/web-security-service-legacy-ipsec-connec.html
> Note: in other articles they have variations in config which i had to follow such as
NAT-T when used, you need to change the IKE ID to the public IP address that the upstreat fw is natting the ASAs outside IP to. I had to do this on the ASA via ASDM, but it can be done on the CLI as
crypto isakmp identity key-id <Public IP Address>
I also didn't follow their advise on 'any' local encryption domain and 'any' remote encryption domain - I caused an outage whilst the firewall tried to bring up the tunnel. instead i used the classless RFC 1918 address as my local encryption domain and ep.threatpulse.net (ip address used) as the remote, i.e. the symantec proxy ip address.
I have other VPN tunnels setup on this firewall and even if my local encryption domain was set to 'any' it would have overlapped with the other tunnels - the firewall did grumble at this!
I did NAT exempt for traffic headed for the proxy ip address for http and https.
I used the same phase 1 and phase 2 settings and whats interesting is that Symantec in Phase 1 tries to negotiate 3DES / SHA DFH grp5.... strange.... The ASA didnt like..
I went through the setup with Symantec over the WebEx and they said it looked ok, however they didnt see any errors or messages that would indicate that phase 1 was unsuccessful. At my end though all i ever got when running show crypto ikev1 sa was the message telling me it was waiting for a response from symantec:
State : MM_WAIT_MSG6
Even if i change the phase 1 params to 3des sha DFH group 5 it still doesn't come up.
Its not successfully negotiating phase 1
Anyone else experiencing this issue and the lack of support from Symant
1 条回复1
share below
1-capture CAP interface OUT match ip host <peer IP> any
2- debug crypto ikev1 127
MHM
快捷链接
