取消
显示结果
搜索替代
您的意思是:
查看次数
29
有帮助
15
评论
Kagamigawa
CISCO URL-BASED ROUTING
1、 终端需求:
能够为LAN区域的终端及anyconnect拨号客户端下发策略,使终端设备的HTTP(包括TLS)流量能够走正确的路径
2、 中间系统需求:
采用IOS-XE设备及AX许可
3、 基础配置:
WAN口:
interfaceGigabitEthernet1
description WAN
no ip address
negotiation auto
pppoe enable group global
cdp enable
pppoe-client dial-pool-number 1
interfaceDialer1
description WAN
ip ddns update hostname xxx.f3322.net
ip ddns update 3322 host members.3322.net
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp pap sent-username xxx password 7 xxx
ppp ipcp dns request
ppp ipcp route default
LAN口配置:
interface range GigabitEthernet2-6
no ip address
negotiation auto
cdp enable
service instance 1 ethernet
encapsulation untagged
bridge-domain 1
member GigabitEthernet1 service-instance 1
member GigabitEthernet2 service-instance 1
member GigabitEthernet3 service-instance 1
member GigabitEthernet4 service-instance 1
member GigabitEthernet5 service-instance 1
member GigabitEthernet6 service-instance 1
bridge irb
interface BDI1
ipaddress 192.168.0.1 255.255.255.0
ipnbar protocol-discovery
ipnat inside
DHCP配置:
ip dhcp excluded-address 192.168.0.1 192.168.0.50
ip dhcp pool NAT
network 192.168.0.0255.255.255.0
dns-server 192.168.0.1
default-router 192.168.0.1
NAT配置:
ip nat inside source list 1 interfaceDialer1 overload
access-list 1 permit 192.168.0.00.0.255.255
VPN配置
aaa new-module
aaa authentication login sslvpn local
aaa authorization network sslvpn local
crypto ssl proposal sslvpn-proposal
protection rsa-3des-ede-sha1 rsa-rc4128-md5rsa-aes128-sha1 rsa-aes256-sha1
crypto ssl authorization policysslvpn-auth-policy
pool sslvpn
dns192.168.0.1
def-domain uq
crypto ssl policy sslvpn-policy
sslproposal sslvpn-proposal
pkitrustpoint SIG sign
ipinterface Dialer1 port 4443
crypto ssl profile sslvpn-profile
match policy sslvpn-policy
aaaauthentication user-pass list sslvpn
aaaauthorization group user-pass list sslvpn sslvpn-auth-policy
authentication remote user-pass
max-users 100
ip local pool sslvpn 192.168.32.100192.168.32.254
4、 搭建web流量代理服务
iox
app-hostingappid guestshell
app-vnic gateway0 virtualportgroup 0guest-interface 0
guest-ipaddress 192.168.1.100 netmask255.255.255.0
app-default-gateway 192.168.1.1guest-interface 0
name-server0192.168.1.1
interface VirtualPortGroup0
ipaddress 192.168.1.1 255.255.255.0
ip nat inside
安装privoxy与v2ray服务和nginx
Echo “actionsfilegfwlist.action” >> /etc/privoxy/config
listen-address 0.0.0.0:8118 #监听LAN的数据
下载gfwlist.action文件到/etc/privoxy目录
启动v2ray服务
[root@guestshellguestshell]# systemctl status v2ray.service
● v2ray.service -V2Ray Service
Loaded: loaded(/etc/systemd/system/v2ray.service; enabled; vendor preset: disabled)
Active: active (running) since Fri2020-12-25 12:48:30 UTC; 3 days ago
Main PID: 34 (v2ray)
CGroup:/system.slice/libvirtd.service/system.slice/v2ray.service
└─34/usr/bin/v2ray/v2ray -config /etc/v2ray/config.json
启动nginx服务
在nginx的根目录下创建个proxy.pac文件
[root@guestshellguestshell]# more /usr/share/nginx/html/proxy.pac
functionFindProxyForURL(url, host) {
if (isPlainHostName(host) ||
shExpMatch(host,"*.local") ||
isInNet(dnsResolve(host),"10.0.0.0", "255.0.0.0") ||
isInNet(dnsResolve(host),"172.16.0.0", "255.240.0.0") ||
isInNet(dnsResolve(host),"192.168.0.0", "255.255.0.0") ||
isInNet(dnsResolve(host),"173.37.0.0", "255.255.0.0") ||
isInNet(dnsResolve(host),"127.0.0.0", "255.255.255.0"))
return "DIRECT";
else
return "PROXY 192.168.1.100:8118";
5、 为LAN和anyconnect客户端下发策略
ip dhcp pool NAT
option 252 asciihttp://192.168.1.100/proxy.pac
crypto ssl authorization policy sslvpn-auth-policy
msie-proxy server192.168.1.100:8118
评论
huajiang
此方法有效吗
Kagamigawa
ciscohua0815 发表于 2020-12-31 11:45
此方法有效吗
我家就这么用着呢
Tiandao
给力啊!学习了
述沭
力啊!学习了
wuhao0015
好家伙,我懂的。。。
mxmtec3617967
privoxy,v2ray,都是部署在路由器上的?
Kagamigawa
是的 guestshell
mxmtec3617967
学习了!。。。致敬
huajiang
PAC配置脚本上只把内网网段剥离出来了,其他访问国内外网
Kagamigawa
国内外靠的是 privoxy下的 gfwlist.action文件
fortune
谢谢分享哦
tony huang
Community Member
还能再详细一点吗
niyaodong
高手。这就去试试看。
zeroarynas
这就是<翻><墙>吧,ax的license可以rtu
Hallo,thank you for the teams.support for me update and upgrade my network component.
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
