取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
如何验证,如果EIGRP非终止转发(NSF)功能启用?
lovemilla12
1 个已接受解答
已接受的解答
画心
为了检查EIGRP NSF功能,请发出show ip protocols命令。这是输出示例: :
show ip protocols
; Routing Protocol is "eigrp
101"
; Outgoing update filter list for all
interfaces is not set
; Incoming update filter list for all
; Default networks flagged in outgoing
updates
; Default networks accepted from
incoming updates
; EIGRP metric weight K1=1, K2=0, K3=1,
K4=0, K5=0
; EIGRP maximum hopcount 100
; EIGRP maximum metric variance 1
; Redistributing: eigrp 101
EIGRP NSF-aware
route hold timer is 240s
; Automatic network summarization is in
effect
; Maximum path: 4
;;Routing for Networks:
; Routing Information Sources:
; Gateway;;;;;;;;
Distance;;;;;
Last Update
; Distance: internal 90 external 170
此输出显示路由器是NSF意识的,并且路由保持计时器设置为240秒,是默认值。
在原帖中查看解决方案
1 条回复1
画心
show ip protocols
101"
updates
incoming updates
K4=0, K5=0
EIGRP NSF-aware
effect
; Maximum path: 4
; Gateway;;;;;;;;
Distance;;;;;
Last Update
快捷链接
