取消
显示结果
搜索替代
您的意思是:
查看次数
22
有帮助
30
回复
引起下一跳地址无效的原因
gsm87_qq_com
1、接口配置 :
interface GigabitEthernet0/1
description To DianXinChenYuWan
ip address 117.28.224.145 255.255.255.252
duplex auto
speed auto
media-type rj45
2、配置默认路由:
CT-R7400(config)# ip route 0.0.0.0 0.0.0.0 117.28.224.146
%Invalid next hop address (it's this router)
CT-R7400#ping 117.28.224.146
3、对端接口是ping的通,并且用笔记本电脑设置是可以上互联网。
Sending 5, 100-byte ICMP Echos to 117.28.224.146, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
4、有路由表
CT-R7400#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 61.154.8.185 to network 0.0.0.0
117.0.0.0/30 is subnetted, 1 subnets
C 117.28.224.144 is directly connected, GigabitEthernet0/1
5、路由器版本
CT-R7400#sh version
IOS (tm) 7400 Software (C7400-JK9S-M), Version 12.2(15)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 10-Mar-03 21:47 by ccai
Image text-base: 0x60008954, data-base: 0x62088000
ROM: System Bootstrap, Version 12.2(4r)B1, RELEASE SOFTWARE (fc1)
BOOTLDR: 7400 Software (C7400-KBOOT-M), Version 12.2(4)B4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
CT-R7400 uptime is 33 weeks, 6 days, 16 hours, 15 minutes
System returned to ROM by bus error at PC 0x60102BBC, address 0x0
System restarted at 19:02:19 GMT Mon Nov 9 2015
System image file is "disk0:c7400-jk9s-mz.122-15.T.bin"
6、请问是什么原因?
30 条回复30
a_pan
接口 no ip add 再shut,然后接口 ip add 再no shut;
或者接口 no ip add 再 shut,配置缺省路由,然后再接口 ip add ,no shut 试试
suzhouxiaoniu
问题比较奇怪,不知道楼主有没有解决。
zenglj
看一下 117.28.224.146 该地址是不是被其他设备接口使用了
aisike
支持一下 楼主加油
liuzhi001
从配置上看不出有什么问题,可以把default route配置成指向转发接口gi0/1试试
cxg123456
奇怪的问题,解决了吗?
suzhouxiaoniu
这个问题,不知道有没有解决,希望楼主分享一下
a_pan
gsm87@qq.com 发表于 2016-7-6 14:29
CT-R7400#sh ip int br
Interface IP-Address OK? Method Status ...
建议楼主试试,全局模式下default interface g0/1,把此接口恢复到默认状态,然后再试试能不能把静态路由写上
gsm87_qq_com
a_pan 发表于 2016-11-9 09:18
建议楼主试试,全局模式下default interface g0/1,把此接口恢复到默认状态,然后再试试能不能把静态路 ...
这个方法我试过了,后面想想估计设备挂了
gsm87_qq_com
没,换了路由器了。除了刷机没刷外
Yanli Sun
Community Manager
Community Manager
感谢楼主反馈
gsm87_qq_com
huoran1234 发表于 2016-7-4 15:42
是不是设备上有其他接口配置有相同的地址。。sh ip int b看看
:D没有的,换台路由器没出现这个问题,有问题的路由器 只有这些简单的配置,就2个口内网和外网口+默认路由
gsm87_qq_com
vsop5207 发表于 2016-7-4 20:41
%Invalid next hop address (it's this router) 你这个地址已经配置在了本地路由器,你看看接口地址是不是 ...
不是的哦,默认路由以接口方式去做可以,下一跳不行 sh run 就唯一一条默认路由 不会重复
gsm87_qq_com
这个也试过,不行
最后换设备解决,没有那个老设备的IOS
Yanli Sun
Community Manager
Community Manager
感谢楼主分享解决方案
快捷链接
