取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
11
回复
路由器端口unknown protocol drops
qianzhentian
我的设备是电信光猫-cisco 892fsp - Cisco ap 2802i
查看路由器892fsp发现有丢包。请帮忙看看什么元。谢谢!
端口设置:
接ap 2802i
interface GigabitEthernet0
description Wireless-Access-Point
switchport trunk native vlan 10
switchport mode trunk
no ip address
接电信光猫lan口
interface GigabitEthernet9
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
查看端口结果:
Router#sh int g0
GigabitEthernet0 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 84b2.6179.9855 (bia 84b2.6179.9855)
Description: Wireless-Access-Point
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
Last input 00:00:18, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 19000 bits/sec, 4 packets/sec
567729 packets input, 87917706 bytes, 0 no buffer
Received 49598 broadcasts (103108 multicasts)
0 watchdog, 0 multicast, 0 pause input
795260 packets output, 365584811 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
4002 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
查看g9端口:
Router#sh int g9
GigabitEthernet9 is up, line protocol is up
Hardware is PQ3_TSEC, address is 84b2.6179.9867 (bia 84b2.6179.9867)
Internet address is 192.168.1.2/24
Full Duplex, 1Gbps, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:01, output 00:00:01, output hang never
558306 packets input, 343876006 bytes, 0 no buffer
Received 60410 broadcasts (0 IP multicasts)
435547 packets output, 71356059 bytes, 0 underruns
57523 unknown protocol drops
3 lost carrier, 0 no carrier, 0 pause output
1 个已接受解答
已接受的解答
Rockyw
bobqian 发表于 2019-1-8 12:36
第二个链接点开报Page not found
根据第二个文档的标题在思科的社区搜索一下,或者用谷歌搜索一下看看。
Rockyw | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
11 条回复11
Rockyw
Rockyw
楼主参考一下下面的文档
Solved: unknown protocol drops on interfaces
https://community.cisco.com/t5/routing/unknown-protocol-drops-on-interfaces/td-p/1601638
Unrecognized Protocol Drops
https://community.cisco.com/docs/DOC-15490
qianzhentian
Rocky 发表于 2019-1-7 22:34
楼主参考一下下面的文档
https://community.cisco.com/t5 ...
qianzhentian
可能是被电信等禁止访问吧,更别贴谷歌了。。。
好心人能帮忙粘贴内容过来么,多谢!!!
找不到啊。。。
qianzhentian
以关键词“Unrecognized Protocol Drops”搜cisco.com社区,没有记录。
您资源丰富。好让人羡慕啊。。。
Rockyw
您资源丰富。好让人羡慕啊。。。
能用谷歌是最好的,下面这些也参考一下
Solved: Unknown protocol drops
https://community.cisco.com/t5/switching/unknown-protocol-drops/td-p/1064330
Unknown Protocol Drops
https://learningnetwork.cisco.com/thread/68920
How do I identify unknown protocols on my Cisco 2811?
https://serverfault.com/questions/490154/how-do-i-identify-unknown-protocols-on-my-cisco-2811
qianzhentian
Rocky 发表于 2019-1-8 22:13
能用谷歌是最好的,下面这些也参考一下
参考试验,发现启动了lldp协议后,内网端口好了。但外网端口还是存在该问题。不知道还有什么协议不匹配。有机会慢慢了解。
非常感谢
wuhao0015
无需纠结,我这丢了还多呢。。
NJ-Home-C897#show inter gigabitEthernet 7
GigabitEthernet7 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 885a.92a5.a420 (bia 885a.92a5.a420)
Description: dT:GS108PEv2-G8
Last input 00:00:00, output never, output hang never
5 minute input rate 7000 bits/sec, 6 packets/sec
5 minute output rate 7000 bits/sec, 7 packets/sec
20853153 packets input, 5552518753 bytes, 0 no buffer
Received 148526 broadcasts (181880 multicasts)
29079721 packets output, 29866320815 bytes, 0 underruns
31827 unknown protocol drops
Rockyw
bobqian 发表于 2019-1-9 11:14
参考试验,发现启动了lldp协议后,内网端口好了。但外网端口还是存在该问题。不知道还有什么协议不匹配。 ...
如果对性能和使用没什么影响的话,倒不用太在意
qianzhentian
是的,通过这个过程了解学习。
Rockyw
bobqian 发表于 2019-1-9 13:35
是的,通过这个过程了解学习。
如果可以的话,请将我的回复标记为最佳答案
快捷链接
