取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
8
回复
Why does WAN2 share upload bandwidth with WAN1 when uploading?
weibin
I have two PPPoE connections, WAN1 and WAN2, each with an upload bandwidth of 50Mbps. There are no issues with OpenWRT, but with the Cisco router, WAN2's upload affects WAN1.
Router-C1111#show pppoe session all
Total PPPoE sessions 2
session id: 1
local MAC address: xxxx.xxxx.xxxx,, remote MAC address: xxxx.xxxx.xxxx,
virtual access interface: Vi3, outgoing interface: Gi0/0/0
 VLAN Priority: 0
    77578 packets sent, 84671 received
    16997900 bytes sent, 84662990 received
session id: 1
local MAC address: xxxx.xxxx.xxxx, remote MAC address: xxxx.xxxx.xxxx,
virtual access interface: Vi2, outgoing interface: Gi0/0/1
 VLAN Priority: 0
    19316 packets sent, 42938 received
    3695339 bytes sent, 10995122 received
interface GigabitEthernet0/0/0
 no ip address
 negotiation auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
 pppoe-client dial-pool-number 2
interface Dialer1
 mtu 1492
 ip address negotiated
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer down-with-vInterface
 ipv6 dhcp client request vendor
 ipv6 dhcp client pd isp
 ipv6 address autoconfig default
 ipv6 enable
 ipv6 mtu 1280
 ipv6 tcp adjust-mss 1212
 ppp chap hostname xxxxxx
 ppp chap password 0 xxxxxx
 ppp pap sent-username xxxxxx password 0 xxxxxx
interface Dialer2
 mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 2
8 条回复8
Hi @weibin
Can I see  "show version" command and "show license " command?
Router-C1111#show version
Cisco IOS XE Software, Version 17.15.01a
Cisco IOS Software [IOSXE], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 17.15.1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2024 by Cisco Systems, Inc.
Compiled Wed 21-Aug-24 17:04 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2024 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 17.5(1r)
Router-C1111 uptime is 42 minutes
Uptime for this control processor is 44 minutes
System returned to ROM by Reload Command at 00:15:33 beijing Tue Feb 18 2025
System restarted at 00:19:43 beijing Tue Feb 18 2025
System image file is "bootflash:c1100-universalk9.17.15.01a.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  Smart License  None
securityk9
appxk9
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           appxk9           Smart License    appxk9
uck9             None             Smart License    None
securityk9       securityk9       Smart License    securityk9
ipbase           ipbasek9         Smart License    ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Smart Licensing Using Policy
cisco C1111-4P (1RU) processor with 1337633K/6147K bytes of memory.
Processor board ID FGL2504LHCT
Router operating mode: Autonomous
3 Virtual Ethernet interfaces
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2863103K bytes of flash memory at bootflash:.
Configuration register is 0x102
Router-C1111#show license all
Smart Licensing is ENABLED
License Conversion:
  Automatic Conversion Enabled: True
  Status: Not started
  Last Data Push: <none>
  Last File Export: <none>
Export Authorization Key:
  Features Authorized:
    <none>
Utility:
  Status: DISABLED
Smart Licensing Using Policy:
  Status: ENABLED
  Reporting Mode: STANDARD
Account Information:
  Smart Account: <none>
  Virtual Account: <none>
Data Privacy:
  Sending Hostname: yes
    Callhome hostname privacy: DISABLED
    Smart Licensing hostname privacy: DISABLED
  Version privacy: DISABLED
Transport:
  Type: cslu
  Cslu address: <empty>
  Proxy:
    Not Configured
  VRF: <empty>
Miscellaneous:
  Custom Id: <empty>
Policy:
  Policy in use: Merged from multiple sources.
  Reporting ACK required: yes (CISCO default)
  Unenforced/Non-Export Perpetual Attributes:
    First report requirement (days): 365 (CISCO default)
    Reporting frequency (days): 0 (CISCO default)
    Report on change (days): 90 (CISCO default)
  Unenforced/Non-Export Subscription Attributes:
    First report requirement (days): 90 (CISCO default)
    Reporting frequency (days): 90 (CISCO default)
  Enforced (Perpetual/Subscription) License Attributes:
    First report requirement (days): 0 (CISCO default)
    Report on change (days): 0 (CISCO default)
  Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
  Last ACK received: <none>
  Next ACK deadline: Dec 18 00:41:05 2025 beijing
  Reporting push interval: 30  days
  Next ACK push check: <none>
  Next report push: Feb 18 00:22:24 2025 beijing
  Last report push: <none>
  Last report file write: <none>
Trust Code Installed: <none>
License Usage
hseck9-ALT (ISR_1100_4P_Hsec):
  Description: hseck9
  Count: 1
  Version: 1.0
  Status: IN USE
  Export status: RESTRICTED - ALLOWED
  Feature Name: hseck9-ALT
  Feature Description: hseck9
  Enforcement type: EXPORT RESTRICTED
  License type: Export
appxk9 (ISR_1100_4P_Application):
  Description: appxk9
  Count: 1
  Version: 1.0
  Status: IN USE
  Export status: NOT RESTRICTED
  Feature Name: appxk9
  Feature Description: appxk9
  Enforcement type: NOT ENFORCED
  License type: Perpetual
securityk9 (ISR_1100_4P_Security):
  Description: securityk9
  Count: 1
  Version: 1.0
  Status: IN USE
  Feature Name: securityk9
  Feature Description: securityk9
Product Information
UDI: PID:C1111-4P,SN:FGL2504LHCT
Agent Version
Smart Agent for Licensing: 5.11.7/ce7436a25
License Authorizations
Overall status:
  Active: PID:C1111-4P,SN:FGL2504LHCT
    Status: RESERVATION IN PROGRESS on Jan 25 09:56:57 2021 beijing
    Request code: CB-ZC1111-4P:FGL2504LHCT-B5YjdyPVc-9C
    Status:PAK
Legacy License Info:
  regid.2017-04.com.cisco.ISR_1100_4P_Application,1.0_594066da-7a77-4de1-94be-5f457fc79627:
    DisplayName: appxk9
    Description: appxk9
    Total available count: 1
    Term information:
        License type: PERPETUAL
          Term Count: 1
  regid.2017-04.com.cisco.ISR_1100_4P_Security,1.0_98807f85-97b4-4e3a-bb8f-dc6a9748d566:
    DisplayName: securityk9
    Term information:
          Term Count: 1
  regid.2017-08.com.cisco.ISR_1100_4P_Hsec,1.0_76e2043a-45ba-4350-8804-9a63fed1ace0:
    DisplayName: hseck9-ALT
    Description: hseck9
    Term information:
          Term Count: 1
Purchased Licenses:
  No Purchase Information Available
Usage Report Summary:
Total: 0,  Purged: 0
Total Acknowledged Received: 0,  Waiting for Ack: 0
Available to Report: 3  Collecting Data: 3
Device Telemetry Report Summary:
Data Channel: AVAILABLE
Reports on disk: 0
@weibin
Can you share the router config?
 I believe you might be load balancing traffic between the two wans and that´s why  it is sharing.
If you run a trace route from one PC to the internet a few times, how does it looks like?
I tried connecting WAN2 back to the OpenWRT for PPPoE dial-up, and after connecting it back to the Cisco router, the issue disappears. Each WAN has an upload speed of 50 Mbps. However, if I restart the Cisco router, they share the upstream bandwidth.
I fixed the issue by removing the "ip route 0.0.0.0 0.0.0.0" from the configuration, and that resolved the problem. Thank you for your help.
What is version related to issue? I dont know.
Anyway' when both WAN UP and ypu dont use some load balance sure ypu will get not equal BW between two WAN.
....sorry for some delay in reply I am busy....
MHM
快捷链接
