취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
의견
socui
안녕하세요.
SDWAN Infra 환경에서 사용되는 Edge 장비들은 cEdge(Cisco OS) 와 vEdge(Viptela OS) 2가지 종류로 나눌수 있는데 자주 사용하는 코멘드를 아래와 같이 참조 할수 있도록 정리하었습니다.
IOS-XE OS (cEdge devices)
Viptela OS (vManage/vSmart/vBond/vEdge devices)
BFD
BFD
show bfd history
show sdwan bfd history
show bfd sessions
show sdwan bfd sessions
show bfd summary
show sdwan bfd summary
show bfd tloc-summary-list
show sdwan bfd tloc-summary-list
Certificate
Certificate
show certificate installed
show sdwan certificate installed
show certificate root-ca-cert
show sdwan certificate root-ca-cert
show certificate serial
show sdwan certificate serial
show certificate signing-request
show sdwan certificate signing-request
show certificate validity
show sdwan certificate validity
Control
Control
show control connections
show sdwan control connections
show control connections-history
show sdwan control connection-history
show control connections-info
show sdwan control connection-info
show control local-properties
show sdwan control local-properties
show control statistics
show sdwan control statistics
show control summary
show sdwan control summary
show control valid-vsmarts
show sdwan control valid-vsmarts
show control valid-vmanage-id
Show sdwan control valid-vmanage-id
show control affinity config
show sdwan control affinity config
show control affinity status
show sdwan control affinity status
Notification
Notification
show notification stream viptela
show sdwan notification stream viptela
OMP
OMP
show omp cloudexpress
show sdwan omp cloudexpress
show omp multicast-auto-discover
show sdwan omp multicast-auto-discover
show omp multicast-routes
show sdwan omp multicast-routes
show omp peers
show sdwan omp peers
show omp routes
show sdwan omp routes
show omp services
show sdwan omp services
show omp summary
show sdwan omp summary
show omp tloc-paths
show sdwan omp tloc-paths
show omp tlocs
show sdwan omp tlocs
Policy
Policy
show policy access-list-associations
show sdwan policy access-list-associations
show policy access-list-counters
show sdwan policy access-list-counters
show policy access-list-names
show sdwan policy access-list-names
show policy access-list-policers
show policy app-route-policy-filter
show sdwan policy app-route-policy-filter
show policy data-policy-filter
show sdwan policy data-policy-filter
show policy from-vsmart
show sdwan policy from-vsmart
Security
Security
show security-info
show sdwan security-info
Tunnel
Tunnel
show tunnel gre-keepalives
show sdwan tunnel gre-keepalives
show tunnel statistics
show sdwan tunnel statistics
Config
Config
show running-config
show sdwan running-config
IPSec
IPSec
show ipsec inbound-connections
show sdwan ipsec inbound-connections
show ipsec local-sa
show sdwan ipsec local-sa
show ipsec outbound-connections
show sdwan ipsec outbound-connections
Crash
Crash
show crash
show sdwan crash
show reboot history
show sdwan reboot history
cflowd
cflowd
show app cflowd collector
show sdwan app-fwd cflowd collector
show app cflowd flow-count
show sdwan app-fwd cflowd flow-count
show app cflowd flows
show sdwan app-fwd cflowd flows
show app cflowd statistics
show sdwan app-fwd cflowd statistics
show app cflowd template
show sdwan app-fwd cflowd template
DPI
DPI
show app dpi flows
show sdwan app-fwd dpi flows
show app dpi summary
show sdwan app-fwd dpi summary
show app dpi applications
show app dpi supported-applications
App-route
App-route
show app-route sla-class
show sdwan app-route sla-class
show app-route stats
show sdwan app-route stats
System
System
show version
show sdwan version
show software
show sdwan software
show system statistics
show platform hardware qfp active statistics drop
show log [messages | vsyslog | ...]
show logging process [IOSRP | FTMD | ...] internal
Clear commands
Clear commands
clear app cflowd flow-all
clear sdwan app-fwd cflowd flow-all
clear app dpi all
clear sdwan app-fwd dpi flow-all
clear app log flow-all
clear app tcp-opt expired-flows
Clear Control
Clear Control
clear control connections
clear sdwan control connections
clear control connections-history
clear sdwan control connection-history
clear control reverse-proxy-connections
clear sdwan control port-index
clear installed-certificates
clear sdwan installed-certificates
clear notification stream viptela
clear sdwan notification stream viptela
Clear OMP
Clear OMP
clear omp all
clear sdwan omp all
clear omp peer
clear sdwan omp peer
clear omp routes
clear sdwan omp routes
clear omp tlocs
clear sdwan omp tlocs
Clear Policy
Clear Policy
clear policy access-list
clear sdwan policy access-list
clear policy app-route-policy
clear sdwan policy app-route-policy
clear policy data-policy
clear sdwan policy data-policy
Clear Tunnel
Clear Tunnel
clear tunnel gre-keepalive
clear sdwan tunnel gre-keepalive
clear tunnel statistics
clear sdwan tunnel statistics
Clear DNS
Clear DNS
clear dns cache
clear sdwan dns cache
clear sdwan dns app-fwd cflowd flow-all
clear sdwan dns app-fwd cflowd statistics
clear sdwan dns app-fwd dpi flow-all
clear sdwan dns app-fwd dpi summary
Request commands (Admin-tech etc)
request admin-tech
request platform software sdwan admin-tech
request certificate install <path>
request platform software sdwan certificate install <path>
request controller delete <org-name/serial-num>
request platform software sdwan controller delete <org-name/serial-num>
request controller reset-version-number
request platform software sdwan controller reset-version-number
request csr upload <path>
request platform software sdwan csr upload <path>
request port-hop color <color>
request platform software sdwan port_hop color <color>
request root-cert-chain install <path>
request platform software sdwan root-cert-chain install <path>
request security ipsec-rekey
request platform software sdwan security ipsec-rekey
Request Software
Request Software
request software install <path>
request platform software sdwan software install <path>
request software activate <build>
request platform software sdwan software activate <build>
request software remove <build>
request platform software sdwan software remove <build>
request software reset
request platform software sdwan software reset
request software secure-boot <list/set/status>
request platform software sdwan software secure-boot <list/set/status>
request software set-default <build>
request platform software sdwan software set-default <build>
request software upgrade-confirm
request platform software sdwan software upgrade-confirm
request software verify-image <image>
request platform software sdwan software verify-image <path>
request platform software sdwan vedge_cloud activate chassis-number <chassis num> token <token id>
시작하기
상단의 검색창에 키워드, 문구, 또는 질문을 입력하여 궁금한 내용을 찾아보세요.
이곳에서의 여러분의 여정이 훌륭하기를 바랍니다! 시스코 커뮤니티에 빠르게 익숙해지는 데 도움이 되는 몇 가지 링크를 준비했습니다.
빠른 링크
