취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
Cisco 2811 Incorrectly Reports AC Power Supply After DC Installation
libre1337
Hello Cisco Community,
I recently purchased a used Cisco 2811 router (PID: CISCO2811) and replaced its original AC power supply with a DC power supply. However, the command show env all still shows "Main Power Supply is AC" even though only a single DC power supply is connected. The router boots up normally, and the DC power input is confirmed to be working.
Details:
  • IOS Version: 12.4(17a)
  • Modules Installed:
    • PVDM2-64 (DSP SIMM)
    • NM-16ESW (16-port EtherSwitch)
  • Commands & Outputs:
    Copy
    Download
    Router#show inventory
    NAME: "2811 chassis", DESCR: "2811 chassis"
    PID: CISCO2811, VID: V08,
    NAME: "PVDMII DSP SIMM with four DSPs", DESCR: "PVDMII DSP SIMM with four DSPs"
    PID: PVDM2-64, VID: V01,
    NAME: "16 Port 10BaseT/100BaseTX EtherSwitch", DESCR: "16 Port 10BaseT/100BaseTX EtherSwitch"
    PID: NM-16ESW, VID: V01,
    Router#show env all
    Fan 1 OK
    Fan 2 OK
    Fan 3 OK
    System Temperature: 24 Celsius (normal)
    Environmental information last updated 00:00:05 ago
Issue Summary:
  • The router detects the power supply as AC despite using a DC power unit.
  • I suspect this is an IOS 12.4(17a) bug, but I couldn’t find any official Cisco documentation or Bug ID related to this issue.
Questions:
  1. Has anyone encountered a similar problem with Cisco 2800 series routers?
  2. Is there a known Bug ID or Cisco document addressing this power supply detection issue?
Since this is a second-hand device, I don’t have a Cisco service contract. Any guidance would be greatly appreciated!
Thank you in advance.
4 응답 4
Translator
Community Manager
Community Manager
인벤토리에 PSU가 없습니다.
이 모델이 모듈형 전원 공급 장치를 허용합니까?
모듈형이 아닌 것을 확인했지만, 섀시를 열어서 전원 모듈을 교체할 수 있습니다.
맞습니다. Change Muse 개방형 섀시
아니요. 이 모델에서는 모듈형 전원 공급 장치를 사용할 수 없습니다.
커버를 열고 내부에 전원 공급 장치를 설치해야 합니다. 운영 중 교체 가능한 모듈형 유형이 아닙니다.
빠른 링크
