Admin API bypass code retrieval
Cervero
Community Member
All of the documented functions for retrieving bypass codes include the following note: “Does not return the actual bypass codes.” The Admin panel clearly allows you to show the existing codes. How do you retieve them with the Admin API?
DuoKristina
As you observed in the Admin API documentation, there is no capability for retrieving an actual bypass code. We are aware that some operations lack parity between the API and the Admin Panel and plan to address this in the future.
Duo, not DUO.
Dear Kristina, any roadmap for this? We are getting requests from customers to automate the delivery of bypass codes. Thanks!
Hi @sandro.s!
You can discuss this as a feature request with your Duo account exec, customer success manager, or partnership manager.
Duo, not DUO.
