Hello, I’ve been attempting to move to the Universal Prompt for years, but there has always been technical blockers. With the announcement that support for the Traditional Prompt is ending in the coming months, I’m growing in concern that gaps I’ve ...
Hi All, I am running Exchange 2019 on Server 2019 with the latest CU 13. My configuration is that my exchange server is behind an IIS reverse proxy using url rewrite to rewrite the subdomain back to the exchange server. I do not have any restrictio...
Hi Guys, I need to know, if there is an application that cannot natively implement MFA, is it possible to implement MFA Number Matching to the server/apps using DUO Cisco with absolutely no changes from the application side? for example the type of a...
Hello everyone, we are carrying out a job to renew the VPN portal identity certificate on an ASA computer. When making the change, the AnyConnect pop-up window appears with the following message: "Single sign-on AnyConnect token verification failure"...
Hello everybody,We have situation where there is user lockout policy on domain , after three bad password attempts. We have problem that users lock themselves after one missed duo push.ASA SSL vpn is configured to have 60 second timeout with 10 secon...
Hello all, We are trying to narrow down when a device is added to a user account within Duo. We normally use the Duo PowerShell module(GitHub - mbegan/Duo-PSModule: Duo Admin API Powershell Wrapper Module) to pull a lot of random reports that are nee...
Hi guys, I need to know if is possible use DUO with ISE connected tu Azure AD to give access to our Network equipment using Tacacs+ i already test using duo with duo proxy+ise+ad on-premise, but now i need use ise with azure ad, the idea is not use a...
Hello everyone! Here are the release notes for our most recent updates to Duo. Public release notes are published on the Customer Community every other Friday, the day after the D-release is completely rolled out. You can subscribe to notifications f...
The Cisco Secure Design team wants to better understand how you and your team think about your organization's IT and security needs- especially how your team plans to achieve user protection. If you’d like to be considered for this research, please t...
I try to secure my Cloud Director infra with DUO.I already have the Authentication Proxy running and the AD group of the users is synced and visible in the DUO Admin portal.Within Cloud Director I have added the Authentication Proxy as an LDAP server...
"token" API call for Duo SSO Generic OIDC Relying Parties application returns "id_token" with a lifetime of 5 mins and "access_token" for 60 mins (configurable). Is there a way to configure lifetime for "id_token" as well?
Hi, We are looking for a possible Multi-Factor from our current vendor since they do not support true IPV6. Does anyone know if DUO Security currently supports IPV6 or plans to in the upcoming future as part of their roadmap? Thanks, Kevin C
Created protect application / integration for our Splunk Enterprise (OnPrem), it does call back to the traditional prompt, I'm guessing it doesn't support the Universal Prompt yet? Our security department just wanted it setup internally so they can g...
We have a Fortigate and DC running Duo Auth Proxy service in Azure. Settting up the RADIUS in the fortigate, I can’t seem to get the Connection Status ‘green’. It keeps failing with Can’t contact RADIUS server. LDAP binding to the same server on ...
Hello, everyone, I have a question - we use Office365 and VMware View (Horizon) with instant clones. This means that a new W10 machine is created every time you log in and destroyed every time you log out. However, we have the problem that we have to...
