12-04-2020 05:42 AM
we are developing a prototype portal using angular as front-end and django restframework as backend. Duo authentication has just been added and we successfully receive/acknowledge the duo push requests.
There is one issue though… upon the duo push acknowledge the Web SDK issue back a POST message with the sig_response but angular framework only deals with GET hence it fails with a “Cannot POST /login” error message.
How can we configure duo’s callback action to avoid POST and just load a different page instead ?
Thx,
Andrea
Solved! Go to Solution.
12-05-2020 05:12 AM
issue solved.
Looking at the Duo-Web-v2.js I realized that an hidden form is created upon duo push acknoledge.
If we define a submit_callback during the Duo.init this avoid the hidden’s form submit and give control back to the code.
Below you see I can dump the sig_response and based on that verify and handle 2FA consequently.
Thx.
A.
Duo.init({
  iframe: "duo_iframe",
  host: "■■■■■■■■■■■■■■■■■■■■■■■■■■■",
  sig_request: this.duo_sign_request,
  submit_callback: (data:any) => {
    var elem = document.getElementsByName('sig_response');
    var sig_response = elem[0].getAttribute('value');
    console.log(sig_response)
12-05-2020 05:12 AM
issue solved.
Thx.
A.
Duo.init({
12-12-2020 05:51 AM
fyi…
fully working example:
DevNet Code Exchange: abuzzi-cisco/angular-duo is now published
Thx,
A.
12-14-2020 04:39 AM
Hi Andrea,
Thank you so much for following up here in the community to share the answer you found with others! I’m glad you got the solution you were looking for.
FYI I am going to relabel this to our “Web SDK” category since it’s just a bit more specific to the exact issue you describe. Although “Protecting applications” makes sense and is relevant too, this will help others find the answer too in the future!
