How should we use Duo-Web-v2.js?
coredumperror
I’m developing Duo functionality for my Python/Django app, and I need to make use of Duo-Web-v2.js, but I’m not sure what the best way to use it would be. I can see two possible solutions.
  1. Copy Duo-Web-v2.js out of the duo_web python package and put it into my Django project’s static files folder, so I can load it on the authentication page like a regular django static file, e.g. <script src="{% static 'duo/js/Duo-Web-v2.min.js' %}"></script>
  2. Use <script src="https://■■■■■■■■■■■■■■■■■■■/frame/hosted/Duo-Web-v2.min.js"></script> (It looks like the forum software is censoring the domain for some reason… It’s api.duosecurity. com.
The disadvantage of #1 is that if Duo-Web-v2.js gets updated with a new version of the duo_web project, I have to manually search out that update and copy it into my django app again.
The disadvantage of #2 is that I don’t know if Duo guarantees that that URL will remain valid in perpetuity, or if it will get updated and no longer be backward compatible with the version of duo_web that my app has installed.
Is there a third option I don’t know about? Or perhaps I’m worrying overmuch about #2?
DuoKristina
Approach #1. We don’t expect people to call the hosted js directly. You can watch the repo to know when the SDK gets updated (It’s not something that happens very often).
Duo, not DUO.
DuoKristina
Duo, not DUO.
coredumperror
OK, thanks for letting me know. I’ll watch the repo.
