Web SDK v4 for ASP.net projects
aamir2
Do we know if the v4 of Web sdk for C# will be available soon. Otherwise, if you have step by step instructions/video on how to use OIDC to upgrade an existing v2 SDK, then please inform me. Unfortunately, I don’t find the documentation on the Duo site very helpful.
Thank you
DuoKristina
DuoKristina
Duo, not DUO.
Thank you @DuoKristina! For now, I was able to make it work with sdk v2. I will definitely look into the OIDC library when upgrading our projects.
Thank you.
