ACI and Freeradius
lnrdnl78d
Hi Dears,
did someone meet troubles to deploy authentication of ACI using Freeradius ?
We're deploying it for a customer but ever receive "authentcation reject".
On Freeradius (owner is customer) as av-pairs we asked to configure
following, as we need only one role with full privilege.
file:/etc/freeradius/clients.conf
client *.*.*.* {
        type            = acct
        secret          = *****************
        shortname       = Cisco
        nastype         = cisco
        require_message_authenticator = no
________________________________________
file: /etc/freeradius/users
User_User                      MD5-Password := ""**************************""
                                Service-Type = NAS-Prompt-User,
                                cisco-avpair = 'shell:roles=\"network-admin\"',
                                Cisco-avpair += "shell:domains = all/aaa/read-all(16001)",
                                cisco-avpair += "shell:priv-lvl=15"
User_User.aci                  MD5-Password := "**************************"
                                Cisco-avpair = "shell:domains = all/admin"
That Freeradius is already used to authenticate access to other device (Cisco too) and at begin customer tried to add av-pair to user but then He created a new user (User_User.aci) for test purpose.
Some Idea ?
Thanks in advance
Daniele
Francesco Molino
Have you tried to return shell:domains = all//admin instead of single /.
Also can you check the file /var/log/dme/log/nginx.bin.log to see what it shows when you try to authenticate?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Sig Nine
Hello, Daniele.
Is it possible to try the following settings?
                Cisco-avpair += "shell:domains = all/aaa/read-all/(16001)",
                Cisco-avpair = "shell:domains = all/admin/(16002)"
