ACI basic config help
raza555
Level 5
Level 5
I am new to ACI. I like to keep single Physical domain & AAEP as per attached diagrammed requirement.
Kindly advise that as configured in attached diagram, is it the best approach or there are better ways to do it.
  • BD-Vlan10[subnet:10.10.10.0/24]->EPG-Web[Static Binding:1/10]->Phy Domain[Vlan10, 20]->Phy-AAEP->Phy-Int-Profile[interface 1/10-1/20]->Sw-Profile-Leaf101-102
  • BD-Vlan20[subnet:10.20.10.0/24]->EPG-DB[Static Binding:1/20]->Phy Domain[Vlan10, 20]->Phy-AAEP->Phy-Int-Profile[interface 1/10-1/20]->Sw-Profile-Leaf101-102
2 Accepted Solutions
RedNectar
Hi rizwan555,
You are on the right track. Although I really do think you should do a google search for an ACI Access Policy Chain tutorial.
So here are your choices. All involve settting up an access policy chain so that the VLANs you wish to access will be available on the ports you want.  But to begin, let's look again at your diagram:
Preparation (the Access Policy Chain)
  1. Create a VLAN Pool (say MappedVLANs_VLAN.Pool) with at least two VLANs (VLAN 10 and 20)
  2. Create a Physical Domain (say MappedVLANs_PhysDom) linked to the recently created MappedVLANs_VLAN.Pool
  3. Create an AAEP (say MappedVLANs_AAEP) linked to the recently created MappedVLANs_PhysDom.
  4. Create an Access Port Policy Group (say S.A.Hosts_APPG) linked to the recently created MappedVLANs_AAEP
  5. Create an Interface Profile for Leaf Swtich 101 (say L101_IntProf) and within that interface profile -
    1. Add an Interface selector for port 1/10 (say 1:10_IntSel) and link it to to the recently created S.A.Hosts_APPG
  6. Create an Interface Profile for Leaf Swtich 102 (say L102_IntProf) and within that interface profile -
    1. Add an Interface selector for port 1/20 (say 1:20_IntSel) and link it to to the recently created S.A.Hosts_APPG
  7. Create a Leaf Switch Profile for Leaf Switch 101 (say L101_LeafProf) and within that leaf profile -
    1. Add a Leaf Selector for leaf 101 (say L101_LeafSel) AND
      1. link the Leaf Profile to the recently created L101_IntProf
  8. Create a Leaf Switch Profile for Leaf Switch 121 (say L102_LeafProf) and within that leaf profile -
    1. Add a Leaf Selector for leaf 102 (say L102_LeafSel) AND
      1. link the Leaf Profile to the recently created L102_IntProf
Option#1 - Tenant config - Network Centic Approach#1 (Old but true)
  1. Create a Tenant (say TenantX)
    1. Within TenantX, create a VRF (say Production_VRF)
    2. Within TenantX, create a Bridge Domain (say Web_BD) linked to Production_VRF
      1. Add a Subnet to the BD of 10.10.10.x/24
    3. Within TenantX, create a Bridge Domain (say DB_BD) linked to Production_VRF
      1. Add a Subnet to the BD of 10.20.10.x/24
    4.  Within TenantX, create an Application Profile (say Production_AP)
      1. Within Production_AP add an Application EPG (say Web_EPG)
        1. Link Web_EPG to the Web_BD
        2. Link Web_EPG to the MappedVLANs_PhysDom
        3. [Static Map Option] Add a static path to Leaf101/1/10 vlan 10 (tagged or 802.1P depending on whether your host is sending tagged or untagged frames)
      2. Within Production_AP add an Application EPG (say DB_EPG)
        1. Link DB_EPG to the DB_BD
        2. Link DB_EPG to the MappedVLANs_PhysDom
        3. [Static Map Option] Add a static path to Leaf102/1/20 vlan 20 (tagged or 802.1P depending on whether your host is sending tagged or untagged frames)
Option#2 - Tenant config - Network Centic Approach#2 (VERY network centric )
        3. Add a Subnet to the Web_EPG of 10.10.10.x/24
        4. [Static Map Option] Add a static path to Leaf101/1/10 vlan 10 (tagged or untagged depending on whether your host is sending tagged or untagged frames)
        3. Add a Subnet to the DB_EPG of 10.20.10.x/24
        4. [Static Map Option] Add a static path to Leaf102/1/20 vlan 20 (tagged or untagged depending on whether your host is sending tagged or untagged frames)
Option#3 - Tenant config - Application Centric Approach
    2. Within TenantX, create a Bridge Domain (say Production_BD) linked to Production_VRF
      2. Add a second Subnet to the BD of 10.20.10.x/24
    3.  Within TenantX, create an Application Profile (say Production_AP)
        1. Link Web_EPG to the Production_BD
        3. [Static Map Option] Add a static path to Leaf101/1/10 vlan 10 (tagged oruntagged depending on whether your host is sending tagged or untagged frames)
        1. Link DB_EPG to the Production_BD
        3. [Static Map Option] Add a static path to Leaf102/1/20 vlan 20 (tagged or untagged depending on whether your host is sending tagged or untagged frames)
Option#4 - Tenant config - Somewhat Hybrid Approach
        4. [Static Map Option] Add a static path to Leaf101/1/10 vlan 10 (tagged oruntagged depending on whether your host is sending tagged or untagged frames)
Options#5 - 8 -  EPGs mapped to AAEP approach
  1. Create a Tenant (say TenantX) and follow Options 1-4 above EXCEPT the [Static Map Option]
  2. In the Access Policy Chain, locate the MappedVLANs_AAEP: [Fabric Policies > Access Policies > Policies > Global > Attachable Access Entity Profiles - I spent 2 hrs looking for that option one night]
  3. Within the MappedVLANs_AAEP, add an Application EPG
    1. Link it to TenantX, Application Profile Production_AP, EPG Web_EPG, Encap vlan-10 (tagged or untagged depending on whether your host is sending tagged or untagged frames)
  4.  Within the MappedVLANs_AAEP, add a second Application EPG
    1. Link it to TenantX, Application Profile Production_AP, EPG DB_EPG, Encap vlan-20 (tagged or untagged depending on whether your host is sending tagged or untagged frames)
With Options 5-8, you will now be stuck with VLAN 10 ALWAYS being mapped to the WEB_EPG and VLAN 20 ALWAYS being mapped to the DB_EPG for all switch ports that link back to the MappedVLANs_AAEP - but that is probably a good thing.
So there you go. Eight options to choose from. My preference. Probably Option #7 - ie like Option #3 but using the EPGs mapped to AAEP approach.
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
No problem. I actually added another variation just for completeness, so now there are eight options!
5 Replies 5
raza555
Level 5
Level 5
1) BD-Vlan10[subnet:10.10.10.0/24]->EPG-Web[Static Binding:1/10]->Phy Domain[Vlan10, 20]->Phy-AAEP->Phy-Int-Profile[interface 1/10-1/20]->Sw-Profile-Leaf101-102
2) BD-Vlan20[subnet:10.20.10.0/24]->EPG-DB[Static Binding:1/20]->Phy Domain[Vlan10, 20]->Phy-AAEP->Phy-Int-Profile[interface 1/10-1/20]->Sw-Profile-Leaf101-102
RedNectar
Hi rizwan555,
I hope this helps
Hi RedNectar,
Thank very much for very detailed & complete solution. It very much appreciated.
That's the best explanation, i have ever found on web.
Further comparison between Network Centric vs Application centric has crystal clears my understandings about this concept.
Thanks and Kind Regards
Thankyou very much.
