ACI Design Recommendation
ADC Lane
Hi Team ,
I am going to deloy ACI with diagram as below
Could you help me review, is it fine in production environment ?
Maybe I will L3 out to Firewall and fabric as L3 (GW in fabric), no use managed mode for ADC/FW. Please help share me your recommend !
Thank you in advance !
naveeku6
Thanks for your response, This is pretty much possible, please fine below answer.
If you are using an ACI L3Out to route traffic to an external network and don't want to use the L4-7 graph for additional services, you can configure OSPF as the routing protocol and use a Bridge Domain (BD) as the gateway for the external network.
To do this, you can follow the below steps:
  1. Create a Bridge Domain (BD) in the ACI fabric and associate it with a VLAN or subnet.
  2. Create an L3Out external network in ACI that represents the external network connected to the firewall.
  3. Create a border leaf node profile that defines the connection between the ACI fabric and the external network.
  4. Configure the L3Out connection policy that specifies the OSPF routing protocol and filters used to route traffic between the ACI fabric and the external network.
  5. Configure OSPF on the firewall and advertise the subnet associated with the BD as a network that the firewall can reach.
  6. Configure the BD as the default gateway for the external network, either by configuring a static route or through OSPF.
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
naveeku6
I understand that you are trying to do L3 OUT with Firewall without using  L4-L7 graph. Could you please confirm what deployment type you are using?
Hi @naveeku6 ,
Yes, I will use L3OUT and don't use L4-7 graph . L3out will use OSPF and BD as Gateway
It's possible to use the deployment ACI type in production environment ? Pleases help share yours recommendation !
naveeku6
ADC Lane
Hi @naveeku6
I am really appreciate about this. this help me a lot !
