ACI EIGRP L3OUT Minimum bandwidth
joeharb
Level 10
Level 10
I have EIGRP established and exchanging routes between ACI and Nexus 7K's.  Everything is working but the routes learned from ACI are showing:
Minimum bandwidth is 100000 Kbit
The links between the two are 10GB, I I have tried to change EIGRP Interface policy but it doesn't seem to make any changes.
Joe
9 Replies 9
Robert Burns
Which version of ACI are you running?
General Tip: When posting a quesiton for help, give as much detail as possible to help us help you.  topology, outputs of interface info, SW/HW versions etc at min.
Robert
 ACI version: 5.1(2e)
EIGRP established between Nexus 7K and ACI.
Pad_7K_1-Pad_7K_Core1# show interface ethernet 1/10
Ethernet1/10 is up
admin state is up, Dedicated Interface
Hardware: 1000/10000 Ethernet, address: 4055.3922.4b42 (bia 00d6.feb1.de99)
Description: *** Connection to Leaf 103 Port 48 ***
Internet Address is 10.X.X.X/30
MTU 9000 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is routed
full-duplex, 10 Gb/s, media type is 10G
Pad_7K_1-Pad_7K_Core1# show ip eigrp topology 192.168.34.0/24
IP-EIGRP (AS 100): Topology entry for 192.168.34.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 51456
Routing Descriptor Blocks:
10.X.X.34 (Ethernet1/10), from 10.X.X.34, Send flag is 0x0
Composite metric is (51456/51200), Route is External
Vector metric:
Total delay is 1010 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1492
Hop count is 1
Internal tag is 0
External data:
Originating router is 192.168.200.103
AS number of route is 0
External protocol is Static, external metric is 0
Administrator tag is 0 (0x00000000)
Joe
Thanks Joe - can you give me the same interface outputs from ACI switch side.  Also include a "show lldp nei".
Robert
Also, are you setting the bandwidth in the EIGRP interface policy by chance?
Robert
joeharb
Level 10
Level 10
Leaf103# show interface ethernet 1/48
Ethernet1/48 is up
Port description is L3 OUT to 7K#1 ETH 1/10
Hardware: 100/1000/10000/25000/auto Ethernet, address: 0022.bdf8.19ff (bia 14a2.a037.fd70)
Internet Address is 10.3.26.34/30
MTU 9000 bytes, BW 10000000 Kbit, DLY 1 usec
Port mode is routed
LLDP is not enabled on the 7K but CDP is...
Pad_7K_1-Pad_7K_Core1# show cdp neighbors interface ethernet 1/10
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
S - Switch, H - Host, I - IGMP, r - Repeater,
V - VoIP-Phone, D - Remotely-Managed-Device,
s - Supports-STP-Dispute
Device-ID Local Intrfce Hldtme Capability Platform Port ID
Leaf103(FLM254XXXXX)
Eth1/10 155 R S s N9K-C93180YC-FX Eth1/48
I do have an eigrp policy in place but it set exactly like your screenshot with a "0" value.  I have tried to modify it but it doesn't see to make any difference.
Joe
Hi Joe,
So the interface policy isn't relevant here since this is an external route (assume its a BD route since it says redistributed static).That policy only will affect internal eigrp routes. If its not a BD route redistributed into EIGRP let me know and the policy will be applied somewhere else when I explain how to configure this at the bottom.
First off as far the the minimum bandwidth part goes:
"Minimum bandwidth is 100000 Kbit"
That is just the lowest bandwidth along the path, not necessarily the bw speed of this link. I assume somewhere in this setup there is a 100MB link so thats why you see that. You can manipulate that "minimum bandwidth" simply by setting the bandwidth on the interface you are using or EIGRP:
example...
interface Vlan1303
  no shutdown
  ip bandwidth eigrp mg 10000000 <———
  vrf member mg
  bfd interval 250 min_rx 250 multiplier 3
  ip address 13.13.13.2/24
  ip router eigrp mg
As far as actually manipulating the composite metric of that external route, you have to do that with a route-map in ACI. Here is how you do it
1) Create Route-Map Under L3 out
Screenshot 2023-05-08 at 1.27.03 PM.pngScreenshot 2023-05-08 at 1.27.12 PM.png
2) Apply Route-Map to BD (static route) under the BD -> L3 Configurations
I also filed to reduce confusion when configuring these route-maps
https://bst.cisco.com/bugsearch/bug/CSCwa81257
https://bst.cisco.com/bugsearch/bug/CSCwa81256
Hope this makes sense.
-Michael G
Robert Burns
Your links between the N7K & ACI are indeed operating at 10G - Nothing to worry about there.  Somewhere in your EIGRP topology you likely have a link that's 100Mb - that's what the topology output command is indicating.  It's the lowest bw link in the routing domain used to calculate routing decisions end to end.
Robert
joeharb
Level 10
Level 10
That is the confusing part to me, where is the 100Mb connection since I am looking at the route from the 7K and it is directly connected to the Leaf.  The Leaf and 7K are neighbors, with 10G interfaces.  The reason I am looking into this is we have unequal paths between 2 of our Datacenters and I would prefer the traffic between networks that reside within ACI at the respective DC to traverse the 10G link.
Joe
joeharb
Level 10
Level 10
I am going to open a TAC case to see if I can get some insight on this issue.
Joe
