ACI - How to delete easily all EPG static path on an interface
ju.mahieu
We have a lot of Epg - static path on each physical port on the fabric.
I would like to find an easy way (Gui, CLI or Ansible) to default an interface and delete all the static path binded ?
Below an example of the configuration I need to delete:
moquery -c fvRsPathAtt | grep dn | grep eth1/7
dn : uni/tn-mytenant1/ap-app1-app/epg-app1-epg/rspathAtt-[topology/pod-1/paths-101/pathep-[eth1/7]]
dn : uni/tn-mytenant1/ap-app2-app/epg-app2-epg/rspathAtt-[topology/pod-1/paths-101/pathep-[eth1/7]]
dn : uni/tn-mytenant2/ap-app3-app/epg-app3-epg/rspathAtt-[topology/pod-1/paths-101/pathep-[eth1/7]]
dn : uni/tn-mytenant2/ap-app4-app/epg-app4-epg/rspathAtt-[topology/pod-1/paths-101/pathep-[eth1/7]]
Any ideas...
Thank you
Ju
ju.mahieu
Hi Experts,
I still have this kind of usecase. Any ideas to help ?
Thank you
Ju
Hi Ju
This article may provide help for your case:
https://www.richardstrnad.ch/posts/aci-bulk-delete-dns/
  1. Create a file containing the dn's to delete (one dn per line) directly on the APIC
  2. Delete the dn's using the following command:
    cat foo.txt | while read f; do icurl -g -k -X DELETE https://localhost/api/mo/"${f}".json; done;​
Kind Regards
Jonas
