04-15-2025 04:37 AM
We are in the process of implementing new Cisco Catalyst 9600 switches in a VSS (Virtual Switching System) setup as our new core. We plan to connect these to our existing ACI fabric using an L3 port-channel.
Our plan is to configure a Layer 3 port-channel from the ACI leaf switch and associate it with an existing L3Out.
My question is:
Is it supported to configure the L3 port-channel with one link going to each VSS member switch (i.e., dual-homing to both VSS members), or do both links in the port-channel need to terminate on the same VSS member?
Appreciate any guidance or best practices for this kind of integration.
Solved! Go to Solution.
04-17-2025 08:12 PM
@muhammad-nouman wrote:
My question is:
Yes, it is supported and, in fact, recommended to configure the L3 port-channel with one link going to each VSS member switch. This provides redundancy and maximizes bandwidth utilization.
Please consider the following for the purpose of this configuration:
L3Out Configuration
Port-Channel Configuration
VSS Configuration:
Routing Protocol
Hope This Helps!!!
AshSe
Community Etiquette:
04-17-2025 08:12 PM
My question is:
L3Out Configuration
VSS Configuration:
Routing Protocol
Hope This Helps!!!
AshSe
