ACI - leaf capacity dashboard, how does it calculate LPM usage?
Wojciech Mitus
Hi, i'm trying to create a python script which would gather some of the data available on APIC leaf capacity dashboard. Using API inspector, i was able to get most of API calls used by this dashboard and create appropriate calls for various resources (VLAN's, EPG's, L2 endpoints, L3 prefixes, etc.) in Python, but i can't find a call which would return LPM usage per leaf, so i guess this is somehow calculated from other variables by the dashboard code.
Question is: how can i get/calculate LPM usage per leaf using APIC API calls?
Wojtek
Marcel Zehnder
Hi, you can get the max value for LPM's per leaf by quering these two classes:
configprofileEntity (attribute LPM is the max value for a specific profile)
topoctrlFwdScaleProf (leaf/profile mapping)
These will give you the "100% numbers" - whats missing now is the actual LPM size per leaf - I let you know as soon as I find the correct class.
Hi Marcel, were you able to find something? I'm still struggling with calculating LPM size per leaf using API.
Thanks.
Wojtek
