ACI management ip
Mary
there is one ip address which can manage entire ACI fabric, but i forget, I can loging to apic controller, may i know from apic controller, how to find management ip of aci fabric
Rick1776
Level 5
Level 5
You can do it two ways. I believe you can log into the CIMC for the servers and look at the interface configuration from there or console into the apic controller and issue the command
 show inband-mgmt
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/kb/b_KB_Configuring_Static_Management_Access.html
Rick1776
Level 5
Level 5
RedNectar
HI jolinchewjb
Once you have logged into the controller, type:
ifconfig oobmgmt
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
gmonroy
jolinchewjb,
    Just to clarify your question a bit, there is no "single mgmt ip address" for the entire ACI fabric. Please see the following table for a brief explanation of Device mgmt IPs and what they can be used for. To note, you are likely looking for the APIC Node mgmt IPs:
 Apic Node
  • Out-of-band/In-band mgmt ip. Used for:
    • Fabric Configuration/Management
      • HTTP/HTTPS (GUI/API)
      • SSH (NXOS Style CLI)
    • VMM Domain Integration
    • Managed L4-L7 Services
    • Other mgmt services (NTP, AAA, etc)
Note: Each APIC Node should have a oob/inb unique mgmt IP.
Switch Node
    • Hardware programming verification (show cmds)
Note: Each Switch Node should have a oob/inb unique mgmt IP.
Finding APIC mgmt IPs
Via APIC CLI (ssh to apic mgmt ip):
Method 1:
# ifconfig oobmgmt
This will give you the mgmt ip of the apic you are currently on.
Method 2:
# moquery -c mgmtRsOoBStNode | grep "addr\|#\|rn"
This will give you every configured mgmt ip (apic and switch nodes)
Method 3:
# bash
> acidiag avread | grep -oP "oob address(.*?)\s"
This will give you all APIC mgmt IPs. May need to be "admin".
Via GUI
Method 1:
System > Controllers > expand Controllers folder > select Node-x > General > Shows both oob/inb ips
Method 2: (if static assignment used)
Tenants > mgmt > Tenant mgmt > Node Management Addresses > Static Node Mangement Addresses
Method 3: (if dynamic assignment used
Tenants > mgmt > Tenant mgmt > Node Management Addresses > default (or other named policy)
Cheers,
Gabriel
