ACI Multi-POD / Not able to ping across DC
Ashish Takawale
Hi Membars,
I have ACI Multi-POD setup in my DC, I have 2 POD (1 & 2) connected through IPN, ACI discovery is completed in both the POD's. Now I am not able to Ping from from POD 1 server to POD 2 sever within same Tenant, the server belongs to same EPG.
I am attaching the diagram fro reference, according to diagram I cannot ping from 10.1.1.2 to 10.1.1.3 and vice versa.
Can you please suggest what could be the possible reason.
Br,
Ashish Takawale
stcorry
Hello! Can you please check that your multicast configuration is correct on the IPN? This is a typical reason for being unable to ping. Please verify you see the correct groups on the IPN. You can also try to use the troubleshooting wizard between these two EPs.
