ACI Multi-Site Initialization question
SIMMN
I have two Datacenters and I need to setup ACI multi-site for brownfield migration. To initialize each ACI Fabric for preparing the Multi-Site setup, I need to configure Fabric name, ID, Infra VLAN/Subnet and MCast for each. So the questions I have:
1. Can Fabric ID be the same for the two sites?
2. Can Infra VLAN (not subnet) to be the same for the two sites?
3. Is VLAN 4 reserved strictly for ISN/IPN network? In other words, I can not use VLAN4 as Infra VLAN, right?
4. If #3 is true, what happens if VLAN 4 is used already as Data VLAN within Datacenter?
ACI Code v4.2.
Thanks!
Robert Burns
Robert - Yes.  Fabric ID should always be "1".  There's no longer any use case for changing this.  Site ID is assigned by MSite and the differentiating identifier.
Robert - Yes.
Robert - The IPN/ISN VLAN is strictly for the OSPF connection between Spines and ISN.  This doesn't impact the ability to use VLAN 4 as a User/Data VLAN.  This infra VLAN is in its own VRF.
Robert - Not an issue.
Thanks!!!
So just I am clear, I could use VLAN 4 as the ACI Infra VLAN while perform OSPF peering for ISN/IPN via VLAN4?
It would not cause any issue if I used Fabric ID 1 for one site and Fabric ID 2 for the second site, right? I thought there was some specific use case, may be GOLF?, that the Fabric IDs must be unique...Maybe it is irrelevant now with v4.2 or 5...
