07-01-2020 09:49 AM
ello All,
We have scenario where Multiple EPGs are configured under same Bridge Domain(BD), would like to understand IP assignment for node ...For eg :
BD : bd_shared_service , BD Subnet : 10.10.10.0/24
EPG-1 : epg_ss_10
EPG-2 : epg_ss_20
We have configured node with VLAN10 (i.e EPG-10) and node with VLAN20(i.e. EPG-20) how the DHCP IP assigment has been done from subnet 10.10.10.0/24 because it's sharing among 02 BDs.
Can define or reserved the IP range for EPG wise anywhere in ACI. Eg: 10.10.10.1 - 10.10.10.100 for VLAN-10(EPG-10) and 10.10.10.101 - 10.10.10.254 for VLAN-20 (EPG-20).
Do we require any additional configuration.
Rgds
07-01-2020 11:25 PM
Hi ...
Can anyone suggest....
07-02-2020 08:22 AM
Hi @netbeginner
I would suggest you to read the attached documents: https://community.cisco.com/t5/data-center-documents/technote-on-dhcp-relay-in-aci/ta-p/3161830
From ACI perspective, there is no config which will allow you to reserve ranges for EPGs.
Best regards,
Sergiu
