ACI MultiPod - 1 L3OUT per Site OR 1 L3OUT Across Pods
Ibrahim Jamil
Level 7
Level 7
Hi Freinds
L3OUT Q
1. when we design Multipod , what is the Recommendation with regard to L3OUT ? 1 L3OUT per Site OR 1 L3OUT Across Pods , pls note that is Active/Active  Span Ether channel cluster FW across Pods ,
VMM Q
2. with regard to VMM , what is the Recommendation , 1 VMM per Site OR 1 VMM across sites
ServiceChain Q
3. we are planing to use Service chain (FW + SLB) , How the Design looks like ?
thanks all
Ibrahim
Ali Aghababaei
Level 3
Level 3
Hi @Ibrahim Jamil
L3OUT Q
Based on  pages 57 and 58 of Cisco Live BRKDCN-2949 document which you can find it on this link (https://www.ciscolive.com/c/dam/r/ciscolive/global-event/docs/2023/pdf/BRKDCN-2949.pdf)
Local L3Outs preferred over L3Outs in remote pods
Remote pod L3Out may be used if it has a better external metric
Also You will find it useful (Pages 67-68)
Please mark answers as correct if it solve your problem.
Ali Aghababaei
Level 3
Level 3
Hi @Ibrahim Jamil
VMM Q
2. with regard to VMM , what is the Recommendation , 1 VMM per Site OR 1 VMM across sites:
I found the below information useful in ACI Advanced Monitoring and Troubleshooting book which you can find here :
https://www.ciscopress.com/store/aci-advanced-monitoring-and-troubleshooting-9780135264720
Pages 327-330
AliAghababaei_1-1718899280797.pngAliAghababaei_2-1718900188576.pngAliAghababaei_3-1718900269496.png
Ali Aghababaei
Level 3
Level 3
Hi @Ibrahim Jamil
ServiceChain Q
First of all at this time, it seems you can chain UP to 5 services:
Also you can watch this video, I'm sure it will be helpful:
https://www.youtube.com/watch?v=VeWbOl31UIM
Ibrahim Jamil
Level 7
Level 7
Hey Ali
Thanks a  lot seems helpful , kindly follow my ACI Posts,Questions
