ACI MultiPod Independet Firewalls per pod
spinning2008
Hi team,
I need some guidance regarding an ACI Multi-Pod design and would like to know the best recommendation.
The design includes three firewalls per data center: MPLS, SD-WAN, and INET (active-standby independent), each connected to a separate L3Out. To ensure symmetric traffic, PBR seems like the best choice, correct? I also plan to use AS-path prepending.
Would you recommend any additional best practices or considerations?
Looking forward to your advice.
Best regards.
AshSe
Hello @spinning2008
Your plan to use PBR and AS-path prepending is a solid foundation. Pay close attention to the details of your L3Out design, contract design, PBR implementation, and firewall configuration. Thorough testing and comprehensive monitoring are essential for a successful ACI Multi-Pod deployment. Remember to document everything!
You may share (if doesn't breach your NDA agreement) your specific design for detailed response.
Hi  AshSe
thanks for the reply, I'm still checking the design, cisco does not reommed using for example  0.0.0.0/0  in multiple L3out, can use 0.0.0.0/1 + 128.0.0.0/1 in 1 L3out and 0.0.0.0/0 in another L3out. Best solution is use 1 L3out with multiples eBGP sessions ??
Thanks and regards,
