ACI Route Leaking :how to prevent default route to be imported ?
tlequertier
I use route leaking between sources EPGs in VRF_A and destination EPGs in VRF_B.
VRF_A has a L3OUT connected to and the default route 0.0.0.0/0 of VRF_A is to the L3OUT network.
The bad result of hat for me is that the default route to VRF_A L3OUT is imported in the target VRF_B which ....had already another default so the conflict.
 my question: is it possible to prevent the default route of VRF_A to be imported in the VRF_B?
7 Replies 7
Marcel Zehnder
Do you need acccess from the external networks behind L3-OUT in VRF_A to VRF_B?
If not, disable the "Shared Route Control Subnet" Option from the external network under the L3OUT-Configuration in VRF_A. This should prevent the routes learned via L3OUT VRF_A to be imported in VRF_B.
Marcel
Hi Marcel,
thanks for your answer,
but yes I need access from the external networks behind L3-OUT in VRF_A to VRF_B. From a specific subnet only (OOB Subnet in fact  10.227.94.0/24 behind the L3OUT).  So if I could import in VRF_B  only the OOB_Subnet  I will get my solution.
Could you please post the configuration of the external network(s) in VRF-A under the L3-Out?
And please also post the routes you receive on the L3out in VRF-A.
Hi Marcel,
I uploaded the L3OUT "XML" definition of the VRF_A (IBM_INFRA_MGMT:IBM_INFRA_MGMT)
I uploaded also the interested parts  ( 0.0.0.0/0 and 10.227.94.0/24 subnets)  of routing table for VRF_A and VRF_B
Try to configure two subnets under the external network, the config should look like in the attached picture.
Marcel
Thanks lot Marcel for your advice.
Can't do the test right now , but i understand the meaning.
