ACI simulator connection to external managment entities
doretteS
i have read from many comments that  The simulator allows you to connect external management entities such as ESX servers, vCenters, vShields, bare metal servers, L4-L7 services, AAA systems, and other physical or virtual service appliances.
but i not found a guide on how to perform this.
can somebody help with any link or guide.
thanks
Robert Burns
There's no special instructions for the Simulator to connected to any of these external systems - it's the same config process as if you were setting them up on a real APIC.  Follow the regular config guides for this.   Just need to ensure the management Interface can reach the external servers in question.
Robert
