ACI - VM Networking - Openstack - Missing + icon
ju.mahieu
Level 4
Level 4
Software version : 2.1(1h)
As you can see attached, the actions/add icon seems to be missing on the "Provider - Openstack" screen.
Maybe a bug or a cosmetic issue.
Could you confirm this behavior is already known and should be solved in the next release ?
Thank you.
Ju
aleccham
Hello Ju,
I am surprised to find that information missing. Can you please confirm that your Openstack instances can ping their configured BD GW.
Also can your Openstack environment successfully push Tenant configuration to the APIC?
aleccham
Hello Ju,
Hi Alec,
My openstack environnement isn't ready yet.
This explains the + icon is missing.
Thank you for your quick answer.
Ju
