APIC event code E4208077
alex guterm
Community Member
Hi guys,
About a month or so I've been facing the event with code E4208077 with a frequency of 1 minute. I could not find it anywhere by the description and the code. Does anyone faced the same and know what it can be related to?
Thenk you.
Description:
IPv4 address is changed to Up, reason Up
Severity:
info
Affected Object:
topology/pod-1/node-206/sys/ipv4/inst/dom-Prod:Prod_VRF1/if-[lo3]/addr-[10.252.0.32/32]
Created:
2022-12-06T09:34:45.455+05:00
Code:
E4208077
Cause:
oper-state-change
Change Set:
ipv4CfgFailedBmp (New: ), ipv4CfgFailedTs (New: 00:00:00:00.000), ipv4CfgState (New: 0), operSt (New: up), operStQual (New: up)
Action:
state-transition
Action Trigger:
oper
Transaction ID:
18374686479721090000
User:
internal
rafalke
Community Member
Hello Alex,
Have you managed to fix this issue?
I'm facing similar issue in  Cisco ACI
Kind Regards,
AshSe
The error code E4208077 typically indicates a problem with the ACI system, such as issues with the network, configuration, communication between devices, or system resources. Specifically, it often points to issues like:
  • Configuration Errors: Problems with the configuration of policies or endpoints.
  • Communication Issues: Failures in communication between ACI components or between ACI and other network devices.
  • Resource Constraints: Insufficient resources or limits being hit within the ACI system.
