APIC Recovery Procedure
nguyenducdu1295
Hi Guys,
I have APIC Cluster, but yesterday had an electric power problem, so cluster APIC down.
After power-up, cluster APIC has an issue, they boot to localhost, not boot to OS ACI.
Can you guys give me a way to fix this?
I read about "APIC Recovery Procedure", is this option helpful?
Many thanks!
6 Replies 6
nguyenducdu1295
Hello, Up
nguyenducdu1295
Hello
Robert Burns
Can you post a screenshot of what you're seeing?
Robert
Hi Robert,
I send screenshot on APIC
I have never seen that before... Does it respond on it's OOB IP to HTTPS or SSH?
Is CIMC access also broken since you are connected with a monitor?
I unfortunately ran into the same issue.  A little annoyed because this was an RMA and out of the box it shipped this way.  But for those who have not found the solution, it is over here.
Steps to Re-Image APIC controller via HTTP server - Cisco
