11-13-2017 06:37 AM - edited 03-01-2019 05:22 AM
Current environment contains a VMM domain with a VLAN pool that dynamically allocates VLANs in the range of 1501-1515. The VMM is associated to an EPG name WKS and allocated vlan 1506 for the EPG. My bare metal/physical domain has a VLAN pool of 100-200 and is set to static allocation. When I add the physical domain to the WKS EPG the servers can only communicate with the BD SVI and not nodes in the VMM domain. When I look at the client end-points under the operations tab on the EPG I see both end-points are marked with different VLANs which makes sense due to the VLAN pools. I was told by the TAC DO NOT overlap VLANs in pools between physical and VMM. If that is in fact the case, how do I get the two domains to communicate in the same EPG, or do I have to create separate EPGs?
Solved! Go to Solution.
11-13-2017 11:28 AM
problem resolved... blew away the entire APP profile and rebuilt from scratch. I can only assume that I missed a setting the first time around. Thanks for the input tho!
11-13-2017 09:33 AM
11-13-2017 10:22 AM
The EPGs are set to Intra EPG isolation : unenforced.
11-13-2017 10:33 AM
11-13-2017 11:17 AM
Tried that and still doesn't work.... I have all of these EPG's pointed back to a single BD with a single subnet. I broke it out further and added an additional VMM EPG. Two different endpoints in the same VMM domain in different EPG's can communicate with each other. I did validate the contract is IP any/any. thoughts?
11-13-2017 11:28 AM
11-13-2017 11:29 AM
Thanks for sharing. Glad it's working
