08-13-2020 09:00 AM
Hi All,
Hope all are doing good....!
Having a query related to Cisco ACI logs related to VMotion (VM movement between ESXi host) or any issue in switching , VLAN movement at backend.
In traditional switching we can easily (sort of) able to get the change in TCN or any Vmotion or MAC flapping, VLAN Information . But i do'nt find any relevant similar logs on ACI APIC GUI which help in investigation such issues.
Please advise.
08-13-2020 12:48 PM - edited 08-13-2020 12:49 PM
Hi @netbeginner
You have several options for investigating endpoint moves:
1. Built-in APIC EP tracker, located in Operations > EP tracker
2. Enhanced EP tracker. This is an app available on: https://dcappcenter.cisco.com/enhancedendpointtracker.html
3. Good old CLI style, directly on the Leaf switch. Here you will need to look over the EPM and EPMC logs:
/var/log/dme/log/epm-trace.txt
/var/log/dme/log/epmc-trace.txt
One command which can be useful:
Leaf101# cat /var/log/dme/log/epmc-trace.txt | grep -A 5 -B 1 "optype.*dead.0001" EP request: optype = UPD; mac = 0000.dead.0001; num_ips = 0 vlan = 32; epg_vnid = 10092; bd_vnid = 16744320; vrf_vnid = 2261000 ifindex = 0x1a016000; tep_ip_tun_ifindex = 0; sclass = 16386 flags = local|MAC|sclass|timer| timestamp = 01/04/1970 05:33:33.389619 [2020 Aug 10 18:21:37.697096980:8727:epmc_pd_bcm_learn_ack:947:t] Acking BCM learn msg with num_entries = 1 -- EP request: optype = ADD; mac = 0000.dead.0001; num_ips = 1 ip[0] = 192.168.101.1; ip_flags = vlan = 32; epg_vnid = 10092; bd_vnid = 16744320; vrf_vnid = 2261000 ifindex = 0x1a016000; tep_ip_tun_ifindex = 0; sclass = 16386 flags = local|IP|MAC|sclass|timer| timestamp = 01/04/1970 05:36:19.221828 -- EP request: optype = UPD; mac = 0000.dead.0001; num_ips = 0 vlan = 32; epg_vnid = 10092; bd_vnid = 16744320; vrf_vnid = 2261000 ifindex = 0x1a016000; tep_ip_tun_ifindex = 0; sclass = 16386 flags = local|MAC|sclass|timer| timestamp = 01/04/1970 05:36:19.405245 [2020 Aug 10 18:24:23.712721198:9051:epmc_pd_bcm_learn_ack:947:t] Acking BCM learn msg with num_entries = 1
Hope it helps!
Stay safe,
Sergiu
08-13-2020 10:48 PM
Hi MSD,
Thanks Surely it helps...
