Cisco ACI and VMM vmware integration
ANAKIN_TN
Im deploying a VMM domain to integrate the esx with aci on my fabric, but a i found some limitations ont it .
The use of Vlan pool and a VMM/AEP profile is limited due to the number of vlan, enabling local vlan option can overuse the TCAM, and is a classic way to do it still using classic vlan
So do you have a better way to do it , whats is the must used solution or common solution for this ?
REgards
RedNectar
Hi @ANAKIN_TN ,
I'm afraid I don't understand your question. Or at least parts of it.
Is 4095 VLANs not enough? If not, I'll explain how you can use more
I have no idea what you mean by "local VLAN". I have never seen this option. Could you perhaps give a reference to where this limitation is documented?
RedNectar aka Chris Welsh.
