Cisco ACI CCI Usage (Consumed Contract Interface)
moj_ccie
Hello community users
I've been using ACI Fabric in our SD-DC in Network Centric model ;
In my migration plan and proposed design, I've faced some practical concept such as "Consumed Contract Interface";
If my contract provider is in another tenant, should I use this and how ?
Thanks - Mojtaba
AshSe
Yes, if your contract provider is in another tenant (Inter-Tenant), you should use the "Consumed Contract Interface" (CCI) to facilitate the communication between tenants in Cisco ACI. The CCI allows an EPG (Endpoint Group) in one tenant to consume a contract provided by an EPG in another tenant. Here’s how you can set it up:
Steps to Use Consumed Contract Interface (CCI)
1. Create the Contract in the Provider Tenant:
  • Log in to the APIC GUI:
    • Open your web browser and log in to the APIC GUI using your admin credentials.
  • Navigate to the Provider Tenant:
    • Go to Tenants and select the tenant that will provide the contract.
  • Create the Contract:
    • Under the selected tenant, navigate to Policies > Contracts.
    • Click on the + (Add) button to create a new contract.
    • Define the contract name and the filters (e.g., protocols, ports) that specify the allowed traffic.
    • Make sure to keep the Scope of the contract as Global
  • Assign the Contract to the Provider EPG:
    • Navigate to Application Profiles > Application EPGs.
    • Select the EPG that will provide the contract.
    • Under the Provided Contracts tab, click + to add the newly created contract.
  • Assign the Gateway to the EPG:
    • Create the EPG Subnet
2. Export the Contract to the Consumer Tenant:
    • Go to Tenants and select the tenant that provides the contract.
  • Export the Contract:
    • Navigate to Policies > Contracts.
    • Select the contract you created.
    • Click on Actions > Export Contract.
    • Choose the target tenant (the consumer tenant) and export the contract.
3. Consume the Contract in the Consumer EPG:
  • Navigate to the Consumer Tenant:
    • Go to Tenants and select the tenant that will consume the contract.
  • Assign the Contract to the Consumer EPG:
    • Select the EPG that will consume the contract.
    • Under the Consumed Contracts tab, click + to add the imported contract.
Example Scenario:
  1. Provider Tenant: Tenant_A
  • Provider EPG: EPG_A
  • Contract: Contract_A
2. Consumer Tenant: Tenant_B
  • Consumer EPG: EPG_B
Summary:
  1. Create Contract_A in Tenant_A and assign it to EPG_A as a provided contract.
  2. Export Contract_A from Tenant_A to Tenant_B.
  3. Check Imported Contract_A into Tenant_B.
  4. Assign Contract_A to EPG_B as a consumed contract.
By following these steps, you can successfully use the Consumed Contract Interface to allow an EPG in one tenant to consume a contract provided by an EPG in another tenant, facilitating inter-tenant communication in Cisco ACI.
AshSe
Please rate this post if it was helpful; your feedback is appreciated!
AshSe
Example Scenario:
Summary:
AshSe
