Cisco ACI integration with Openstack
LalitKameshwar
Visitor
Hello All,
We are looking to integrate Cisco ACI with Openstack however we aren't able to identify the relevant documents which will help us with the integration. There are multiple documents available online however nothing that helps us.
ACI Version: 4.2.1
Openstack Version: 3.18.0
Can anyone please help us with any reference documents that will help us with the same.
Thank You.
Lalit
Hello Gaurav,
Thanks a ton for the response. We had gone through the links that you have shared here and it certainly helps with the understanding however is there a document available which we can refer on the following
a. How to install Plugin on the OpenStack
b. What changes need to be done on the openstack services.
Thank You.
regards,
Lalit
@Gaurav Gambhir wrote:
following links gives you a good start understanding what is needed.
ACI Virtualization Compatibility Matrix
https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/aci/virtualization/matrix/virtmatrix.html
Cisco ACI Installation Guide for Red Hat OpenStack Using OpenStack Platform 10 Director
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/2-x/openstack/osp_director/b_ACI_Installation_Guide_for_Red_Hat_OpenStack_Using_OSP_Director_2_3_x/b_ACI_Installation_Guide_for_Red_Hat_OpenStack_Using_OSP_Director_2_3_x_chapter_0...
Cisco ACI Unified Plug-in for OpenStack Architectural Overview
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/aci/apic/sw/4-x/openstack/Cisco-ACI-Plug-in-for-OpenStack-Architectural-Overview.pdf
