Cisco ACI MultiPod with IPN devices connected using Multiple devices
ccietrainee1
Hi All,
I am working on a HLD where I need to extend my ACI multi pod (Site A) to another Site (Site C) which is located 350 miles away from the existing ACI Main POD. Customer is working with Megaport to provide the connection between these sites. But we dont have the direct connection between these sites. I have connection from Site A to Site B (Transit Site and no ACI POD is there, this is just a transit Site), From Site B , I have another WAN connection to Site C. The overall latency is within the 50ms, so we don't see any issues over there.
I have the following questions
1. Between my IPN devices in Site A and Site C, there are multiple devices. What protocol and feature should be supported on those devices? (Multicast PIM, routing Protocols, any other?)
2. Can anybody share sample configuration for the devices between the IPN and the transit devices?
3. We are going to host only one application environment in the new POD. and there will be only 2 Spine and 2 Leaf switches. How to design OOB for these 4 devices, should I go for another WAN link for OOB management? Can this be simplified for cost optimization.
4.Customer also want to enable MacSec encryption over the WAN links, is it supported? Can anyone share some sample config template?
Thanks and regards,
B Senthil Kumar
AshSe
Dear Senthil Kumar, Wouldn't it be great if you can draw a simple diagram and share across with your query. Anyways, let me help you with a diagram to begin with:
Please let me know if any correction required in the diagram.
Answers to your first two questions:
1. OSPF & PIM
2. Check configuration below:
Steps to Configure Multipod Solution
1.Enabling Features
2.Configuring a VRF Instance
3.Configuring the OSPF Process
4.Configuring Multicast
5.Configuring DHCP Relay
6.Configuring IPN interfaces with DHCP
7.Configuring APIC for Multi-Pod setup
First 6 steps are IPN configuration steps.
1.Enabling Features
feature lldp
feature ospf
feature interface-vlan
feature dhcp
feature pim
2. Configuring a VRF Instance
vrf context IPN-1
3. Configuring the OSPF Process
feature ospf
router ospf IPN
  vrf IPN-1
    router-id 1.1.1.1
    log-adjacency-changes
4. Configuring Multicast
interface loopback1
description BIDIR Phantom RP
vrf member IPN-1
ip address 192.168.100.1/30
ip ospf network point-to-point
ip router ospf IPN area 0.0.0.0
ip pim sparse-mode
vrf context IPN-1
ip pim rp-address 192.168.100.2 group-list 225.0.0.0/8 bidir
ip pim rp-address 192.168.100.2 group-list 239.255.255.240/28 bidir
interface ethernet1/7
 mtu 9150
 no shutdown
interface ethernet1/7.4
  description 40G from p1-ipn1 to Spine-1
  mtu 9150
  encapsulation dot1q 4
  vrf member IPN-1
  ip address 192.168.1.1/31
  ip pim sparse-mode
  no shutdown
