Cisco ACI Simulator 3.2 - Spine 2 not discovered
asif.rehman
I have recently installed ACI Sim 3.2(9d) for my CCIE exam and I am stuck with fabric discovery. Leaf 1, spine 1 and leaf 2 discovers and goes into active status but it spine 2 never shows up. I have rebooted the simulator couple of time, left it for 3-4 hours but no use. Any ideas guys what could be the issue here or is there. a manual way to discover and add it to the fabric.
I am also unable to find the reboot/restart/shutdowns option from apic cli. It requires root access. If i shutdown the controller from gui, it never shuts off. I am just powering off from the VM power shutdown options which is not the correct way and might corrupt the kernal or OS files.
Asif
joezersk
Hi Asif:
What you see is normal.  Given the simulator is limited (and resource intensive) it only has one spine.  I.E - there is no spine 2 to discover.
