Cisco APIC Management Access Policy via CLI?
fc00::/7
In APIC, the status (enabled/disabled) of HTTP, HTTPS, SSH, and Telnet state can be viewed in the following path:
APIC > Fabric > Fabric Policies > Pod Policies > Policies > Management Access
What is the equivalent command for this? I need to get this info via SSH.
APIC# show f?
 fabric-recovery  Show fabric recovery information
 faults           Show fault information
 fips             Show FIPS information
 firmware         Show firmware information
 flow             Show Netflow information
APIC#
Sergiu.Daniluk
What you are looking for is here:
apic# show running-config comm-policy
# Command: show running-config comm-policy
# Time: Wed Apr  1 11:04:55 2020
  comm-policy default
    ssh-service
      admin-state-enable
      exit
    telnet
      no admin-state-enable
      exit
    shellinabox
      exit
    http
      admin-state-enable
      no redirect
      no allow-credential
      visore-access-enable
      enable-throttle
      exit
    https
      admin-state-enable
      allow-credential
      enable-throttle
      use-keyring default
      exit
    performance
      exit
    exit
Sergiu
Sergiu.Daniluk
  comm-policy default
    ssh-service
      admin-state-enable
      exit
    telnet
      exit
    shellinabox
      exit
    http
      admin-state-enable
      no redirect
      no allow-credential
      enable-throttle
      exit
    https
      admin-state-enable
      allow-credential
      enable-throttle
      use-keyring default
      exit
    performance
      exit
    exit
Sergiu
