Cisco VSS and design
binoyingen
Hi all,
I'm trying to create a HA design based on Cisco VSS using 4500X, could you please check the attached diagram and recommend the issues in this design. purpose is to achieve maximum uptime to applications, also suggest which all components require active/active configurations.
BS
dpita
Hello
Are you trying to configure this with the ACI n9k leaf switches? Or was this post intended for a different board/community
