Hi everyone,
Is it possible to running command clear eigrp neighbor soft on Cisco ACI border leaf? For example if using NXOS can achieve with command "clear ip eigrp [eigrp-as] [ip-neighbor] soft". I am using ACI 3.2(6i) version. My case is after upgrade firmware on firewall, core can receive prefix from leaf, but leaf can't receive prefix from core. No filtering/ACL applied on core and leaf. So, I think need command clear eigrp soft on leaf to resync/reset eigrp process but when I check remote to leaf CLI, this command not available.
I check logs on core and leaf regarding eigrp, everything is good.
My topology:
Core N7K<> Firewall PaloAlto (transparent)<> Leaf
Core <[directP2P]> Leaf ---> eigrp peering
- Lathif
