Connect to leaf/spine from APIC with domain authentication
udo.konstantin
for remote working I connect via VPN to a customer network ACI Fabric.
Access to the APIC works fine via GUI and SSH. Currently we have Version 4.2(4k) running.
Access to APIC with SSH:
ssh apic#<domain>\\<username>@<IP address>
But connecting to a leaf or spine from APIC is not possible. The command attach works but it seems to be the leaf/spine doesn't query the AD.
So the command attach <leaf name> shows :
# Executing command: ssh <leaf ID> -b <APIC Infra IP>
Password:
But the "correct" password doesn't work.
Any idea?
udo
Sergiu.Daniluk
Hi @udo.konstantin
Have you tried using SSH command and specifying the domain, instead of using attach command? What is the result?
Sergiu
yes I tried it with SSH. I can connect but the password doesn't work.
