contract_parser.py (Python Script for Contracts)
Waqar675
I have question regarding ACI python script (contract_parser.py), I am not seeing any hit in contract as we can see the hit counter is not incrementing.Please see the below output of script
Tested below three conditions:
1-Permit the ICMP
LEAF-101# contract_parser.py --vrf Cisco:VRF-001
Key:
[prio:RuleId] [vrf:{str}] action protocol src-epg [src-l4] dst-epg [dst-l4] [flags][contract:{str}] [hit=count]
[7:4110] [vrf:Cisco:VRF-001] permit ip icmp tn-Cisco/ap-AP/epg-EPG-002(16386) tn-Cisco/ap-AP/epg-EPG-001(49154) [contract:uni/tn-Cisco/brc-EPG-001--EPG-002] [hit=0]
[7:4104] [vrf:Cisco:VRF-001] permit ip icmp tn-Cisco/ap-AP/epg-EPG-001(49154) tn-Cisco/ap-AP/epg-EPG-002(16386) [contract:uni/tn-Cisco/brc-EPG-001--EPG-002] [hit=0]
2-Permit ICMP with Logging enabled
Key:
[7:4110] [vrf:Cisco:VRF-001] log,permit ip icmp tn-Cisco/ap-AP/epg-EPG-002(16386) tn-Cisco/ap-AP/epg-EPG-001(49154) [contract:uni/tn-Cisco/brc-EPG-001--EPG-002] [hit=0]
[7:4104] [vrf:Cisco:VRF-001] log,permit ip icmp tn-Cisco/ap-AP/epg-EPG-001(49154) tn-Cisco/ap-AP/epg-EPG-002(16386) [contract:uni/tn-Cisco/brc-EPG-001--EPG-002] [hit=0]
3-Deny ICMP with Logging enabled
Key:
[7:4110] [vrf:Cisco:VRF-001] deny,log ip icmp tn-Cisco/ap-AP/epg-EPG-002(16386) tn-Cisco/ap-AP/epg-EPG-001(49154) [contract:uni/tn-Cisco/brc-EPG-001--EPG-002] [hit=0]
[7:4104] [vrf:Cisco:VRF-001] deny,log ip icmp tn-Cisco/ap-AP/epg-EPG-001(49154) tn-Cisco/ap-AP/epg-EPG-002(16386) [contract:uni/tn-Cisco/brc-EPG-001--EPG-002] [hit=0]
Waqar
5 Replies 5
Marcel Zehnder
Are you using policy compression in your filters?
Hi Marcel,
No, the policy compression is not enabled but i did this testing while enabling the policy compression but got the same results, although i am not seeing any hit in the implicit deny filter as well.
Waqar
Do you see hits if you do "show system internal policy-mgr stats" on the corresponding leaf?
Yes, i can see hit if i do "show system internal policy-mgr stats" and the hit counter is incrementing accordingly.
In that case it maybe some kind of parsing error in the contract_parser script. I suggest to reach out to the author of the script (Andy Gossett): https://github.com/agccie. He is also active in the ACI-Facebook group: https://www.facebook.com/groups/1028679983855301
